RAP configuration on 6.4
  • 1.  RAP configuration on 6.4
    Posted Jul 17, 2015 03:06 PM
    I'm having some trouble creating the config for a RAP. Its for an exec and the SSID is one already in our environment.
    Does anyone have a clear config guide for this? I've followed the wizard with no luck, and see some user guide stuff, but it seems all over the place or its older 6.0 stuff and doesn't apply...
    I've configured the group with the profiles, VPN addreses and keys, and whitelisted the aps.
  • 2.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:08 PM
    It hasn't changed much from the current VRD except you can use Activate now.
    Where are you getting hung up? Are you seeing the IPSec traffic on the controller?
  • 3.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:09 PM
     Not on the controller, I can see it coming across the NAT device but no return.
    Thats one place I didn't check... I'll take a look.
  • 4.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:10 PM
    OK. You can run show datapath session table | include 4500.
    Also, check the security logs (show log security 50)
  • 5.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:20 PM
    I'm seeing an IKE Xauth failure for the username/password. Now I can't find where that was! (facepalm)
  • 6.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:21 PM
    Hm. You shouldn't need XAUTH. Can you post a screenshot of your VPN configuration screen from the controller?
  • 7.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:24 PM
    Xauth failure would be if you accidentally provisioned the rap with username and password instead of certificate.
  • 8.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:29 PM
    I unchecked it. I'll purge it and reconfigure accordingly.
    Do I need to generate a certificate for the RAP anywhere?
  • 9.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:31 PM
    Noap
  • 10.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:34 PM
    As long as you're using modern RAPs, the certificates are built-in.
  • 11.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:44 PM
    Its a 205.
    I have to get a RAP3 working, but I switched to the 205 for troubleshooting purposes...
  • 12.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 03:46 PM
    Both the 205 and RAP-3 have TPM chips so they will have a factory certificate.
  • 13.  RE: RAP configuration on 6.4
    Posted Jul 17, 2015 04:02 PM
    I dont have a 4500 session coming across anymore.
  • 14.  RE: RAP configuration on 6.4
    Posted Jul 18, 2015 04:16 AM
    hi playinpearls
    cert rap bring up should require the following few steps only. no vpn profiles, no PSKs etc.
    Controller
    >> define l2tp ip pool
    >> whitelist the ap
    AP
    >> purge ap (or reset via button, making sure it doesnt revert to IAP if it was instant before)
    >> check you working DHCP (type dhcp at apboot, wait, then ping the master ip - make sure it's all fine)
    >> either let it discover and connect to controller, reprovision as rap, or from apboot
       setenv remote_ap 1
       setenv master  <controller ip>
       save
       boot
    that should be it, if it's still stuck after this, you can go into the ap shell and take a look in the file /tmp/rapper.txt and /tmp/sapd_debug_log.txt, these may give you a hint as to any problem. But ultimately, setting it as RAP above and the master IP should be enough to get it talking to the controller.
    regards
    -jeff
  • 15.  RE: RAP configuration on 6.4
    Posted Jul 20, 2015 02:13 PM
    thanks Jeff, thats what I was looking for.
    It turns out that we had the RAP natting through a firewall that wasn't the gateway of the controller, so it was failing at making a complete circle. The controller was sending replies through a different firewall.
