RAP Disconnect broken
  • 1.  RAP Disconnect broken
    Posted May 10, 2020 05:31 AM
    My RAP is disconnect and long time to initiation tunnel (Around 1.30 Hours wait for connected)
    my security log is showing. I not sure of correct configuration or another part of infrastructure.
    May 10 13:20:12 isakmpd[3630]: <103103> <3630> <WARN> |ike| IKE SA Deletion: IKE2_delSa peer:My PB IP :55938 id:3945556667 errcode:OK saflags:0x50100009 arflags:0x5
    May 10 13:20:12 isakmpd[3630]: <103103> <3630> <WARN> |ike| IKE SA Deletion: IKE2_delSa peer:My PB IP:1024 id:3945556670 errcode:OK saflags:0x50100009 arflags:0x5
    May 10 13:20:12 isakmpd[3630]: <103103> <3630> <WARN> |ike| IKE SA Deletion: IKE2_delSa peer:My PB IP :63049 id:3945556668 errcode:OK saflags:0x50100009 arflags:0x5
    May 10 13:35:02 sshd[23027]: <199801> <23027> <INFO> |sshd| Accepted password for admin from 10.11.12.242 port 64535 ssh2
    May 10 13:43:31 dot1x-proc:1[4412]: <124004> <4412> <DBUG> |dot1x-proc:1| send_log_config_message_to_other_dot1x_proc message sent to dot1x 2
    May 10 13:43:31 sshd[3897]: <199801> <3897> <INFO> |sshd| Received SIGHUP; restarting.
    May 10 13:48:26 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Started timer for lbgroup config req msg
    May 10 13:48:36 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Requesting lbgroup config
    May 10 13:48:36 isakmpd[3630]: <103063> <3630> <DBUG> |ike| Sent lbgroup config req msg
    May 10 13:48:36 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Started timer for lbgroup config req msg
    May 10 13:48:46 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Requesting lbgroup config
    May 10 13:48:46 isakmpd[3630]: <103063> <3630> <DBUG> |ike| Sent lbgroup config req msg
    May 10 13:48:46 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Started timer for lbgroup config req msg
    May 10 13:48:56 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Requesting lbgroup config
    May 10 13:48:56 isakmpd[3630]: <103063> <3630> <DBUG> |ike| Sent lbgroup config req msg
    May 10 13:48:56 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Started timer for lbgroup config req msg
    May 10 13:49:06 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Requesting lbgroup config
    May 10 13:49:06 isakmpd[3630]: <103063> <3630> <DBUG> |ike| Sent lbgroup config req msg
    May 10 13:49:06 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Started timer for lbgroup config req msg
    May 10 13:49:10 authmgr[3685]: <124004> <3685> <DBUG> |authmgr| Auth GSM: Num dev_id_cache entries aged = 0
    May 10 13:49:16 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Requesting lbgroup config
    May 10 13:49:16 isakmpd[3630]: <103063> <3630> <DBUG> |ike| Sent lbgroup config req msg
    May 10 13:49:16 isakmpd[3630]: <103063> <3630> <DBUG> |ike| ipc_fpapps_lbgroup_cfg_req Started timer for lbgroup config req msg
    May 10 13:49:17 isakmpd[3630]: <103063> <3630> <DBUG> |ike| My PB IP:65327-> udp_encap_handle_message ver:2 serverInst:0 pktsize:390
    May 10 13:49:17 isakmpd[3630]: <103063> <3630> <DBUG> |ike| My PB IP:65327-> IKE_EXAMPLE_IKE_msgRecv: ip:My PB IPport:65327 server:0 len:390 numSkts:6
    May 10 13:49:17 isakmpd[3630]: <103063> <3630> <DBUG> |ike| My PB IP:65327-> IKE_EXAMPLE_IKE_msgRecv:1533: IKE2_msgRecv Called
    May 10 13:49:17 isakmpd[3630]: <103063> <3630> <DBUG> |ike| My PB IP:65327-> IKE2_msgRecv: dwPeerAddr: b4b776bd wPeerPort: ff2f
  • 2.  RE: RAP Disconnect broken
    MVP EXPERT
    Posted May 11, 2020 03:55 AM
    What is the details of your current environment, e.g firmware version, was this affecting on a single RAPs or multiple RAPs, did you or the controller have any ISP issues at the time?
