RAP error message
  • 1.  RAP error message
    Posted May 30, 2014 03:46 AM
    Anybody know the reason for this message from a RAP -
    sapd's state set to SAPD_STATE_CONFIG_RESET
    This was listed in the show ap debug system status command onder the rebootstrap information.
  • 2.  RE: RAP error message
    Posted May 30, 2014 07:25 AM
    What version of ArubaOS is this?
  • 3.  RE: RAP error message
    Posted May 30, 2014 07:30 AM
    What version of code are you on?
    If you are on 6.1 or 6.2, the SAPD_STATE_CONFIG_RESET message merely means the LMS IP has changed for the RAP.  Was the message preceded by Changing to LMS messages?    In version 6.3, the text of the message was changed to be more meaningful; I think it now states something like "LMS Changed, resetting config and changnig to LMS...."
  • 4.  RE: RAP error message
    Posted May 30, 2014 07:34 AM
    The AOS is 6.1.3.5 and there is only a single LMS address which a VRRP address. There is a change message for the LMS address - perhaps it lost connectivity to the LMS?
    CONFIG_RESET just seemed like there was a more serious problem.
  • 5.  RE: RAP error message
    Posted May 30, 2014 08:14 AM
    MattF,
    Yes, it probably lost connection to the VRRP.  It will try to connect to the VRRP again one more time before bootstrapping and that is probably the message you are seeing;  Either way, you could have a connectivity issue.
