Hi All!
I've got a problem with a RAP (RAP-155) terminating on a MD running 8.6.0.6.
There are lots of other RAPs working fine. Even another RAP at the same remote site is working fine.
I can see the isakmp & ipsec sa get established at which point I can ping the IP address that the RAP is assigned.
The problem is, the RAP doesn't appear in the ap database and the ipsec tunnel drops after 20 seconds or so.
The RAP is being migrated from a 6.x controller so perhaps TFTP connectivity is the issue? I can't see any TFTP traffic in the datapath.
What do you reckon?
Cheers
James Whitehead
