rap licensing
  • 1.  rap licensing
    Posted Mar 06, 2014 08:28 PM
    hello
    im 99% sure but i want to be 100% sure
    You do not need PEFGN license to be able to use RAPS and their awsome VPN GRE Tunnel feature? :)
    As far i remenber the RAP license was merge to the AP license back on 5.x
    I have never sold a Controller without PEFGN license so well now there is a client that does not want it if its not necesary and they will be just using a bunch of RAPS for Remote wireless and tunnel termination on the central site.
    Cheers
    Carlos
  • 2.  RE: rap licensing
    Posted Mar 06, 2014 08:29 PM
    Yes, standard AP license for RAPs.
    PEF-NG if you want to customize roles.
  • 3.  RE: rap licensing
    Posted Mar 06, 2014 08:31 PM
    Thank you Mr. Cappalli now im 100% sure
    There you go your 4 free kudos and accepted solution :D
    Thanks again! now we can finish this quote :)
    Cheers
    Carlos
  • 4.  RE: rap licensing
    Posted Mar 07, 2014 02:09 AM
    Hi Tim,
    I was pretty sure, that PEFNG license is needed for RAP operations. It is however absolutely mandatory for Split-tunneling mode.
    Many regards,
    Marek
  • 5.  RE: rap licensing
    Posted Mar 07, 2014 06:43 AM
    Yes you would need it for split tunneling because that is a custom role.
  • 6.  RE: rap licensing
    Posted Mar 07, 2014 07:47 AM
    In our RAPNG architecture you just need PEF-V license. No ap license on VPN controller. Rap runs in iap mode and all config, provisioning done with Airwave.
  • 7.  RE: rap licensing
    Posted Mar 07, 2014 08:13 AM
    Seth now you got me all confused when i though that i was 100% sure...
    PEF-V license??? thats not the via license? why do i need a via license?
    Policy Enforcement Firewall Virtual Private Network (PEFV)—Enables the roles based Policy Enforcement Firewall for VIA clients. This is a controller license.
    AP Capacity License—For RAP indoor and Outdoor mesh APs. Campus, Remote or Mesh APs can terminate on the controller without the need for a separate license.
    after reading this i was like okay 99% sure i just need ap capacity license so ill ask to be 100%, i ask and now i see your post and im totally confused again haha
    Please explain a little more please?
    Cheers
    Carlos
  • 8.  RE: rap licensing
    Posted Mar 07, 2014 08:15 AM
    Are you doing traditional RAP or next gen IAP-VPN?
  • 9.  RE: rap licensing
    Posted Mar 07, 2014 08:16 AM
    Im using a remote AP
    Forget about the VIA client...
    a physical AP, RAP3, RAP109 those :)
    Thats why he got me confused...
    Cheers
    Carlos
  • 10.  RE: rap licensing
    Posted Mar 07, 2014 08:17 AM
    If you are doing a traditional RAP design and not using custom roles (inc. split-tunneling), then you only need AP licenses.
