RAP local pool too small
  • 1.  RAP local pool too small
    Posted Sep 04, 2012 09:00 AM
    Our RAP Local pool is becoming too small.
    We have 2 masters and 4 localcontrollers. When a RAP boots it will be directed to one of the locals. On all our controllers we have configured the same ip range for the localpool. We used a free subnet on our  wired LAN for our pool.
    Is it possible to change the range  without problems with our active RAP's ? In that case the range will overlap with a subnet on our wired LAN, does this give routing problems? What will happen if I choose a totally different range which is not a part of our wired LAN.
    THX.
  • 2.  RE: RAP local pool too small
    Posted Sep 04, 2012 09:06 AM
    You can choose an unroutable pool for your RAPs and everything will still work correctly...  My personal favorite is 8.8.8.1 to 8.8.8.250.
  • 3.  RE: RAP local pool too small
    Posted Sep 04, 2012 09:16 AM
    What will happen  then with our active RAP's , will they reboot and get the new Ip address? Or  will they loose connection and need a power down before they will be back online again?
  • 4.  RE: RAP local pool too small
    Posted Sep 04, 2012 12:43 PM
    No. The current RAPs will stay up & continue using assigned ip-addresses till then rebootstrap. And new RAPs will get ip from new pool created.
  • 5.  RE: RAP local pool too small
    Posted Sep 10, 2012 02:25 AM
    THX.
    I will make the change.
