RAP NAT-T testing
  • 1.  RAP NAT-T testing
    Posted Aug 05, 2015 07:22 AM
    Hi all, any way to test a NAT-T connection remotely without a RAP??  Have a situation where a RAP wont come in and I need to prove its the firewall config thats incorrect, and the controller/rap is as expected...even though 'show datapath session table | include 4500' shows no hits ??
  • 2.  RE: RAP NAT-T testing
    Posted Aug 05, 2015 07:28 AM
    If show datapath is showing no hits, the UDP traffic is not being delivered by the external firewall or the routing, period.  That needs to be corrected before proceeding.
  • 3.  RE: RAP NAT-T testing
    Posted Aug 05, 2015 08:13 AM
    Cheers Colin, yes I rather expected thats the case, just a matter of convincing them now.
  • 4.  RE: RAP NAT-T testing
    Posted Aug 05, 2015 08:15 AM
    You should have them convince you that they are seeing and passing traffic.
  • 5.  RE: RAP NAT-T testing
    Posted Aug 12, 2015 10:29 PM
    hi stunshot
    An easy way to do RAP test without a RAP is to use ike-scan, check out my post about it here:
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/VPN-issue/m-p/236272/highlight/true#M49061
    regards
    -jeff
