RAP not getting IP from RAP pool
  • 1.  RAP not getting IP from RAP pool
    Posted Dec 31, 2014 10:33 AM
    All,
    I am trying to migrate some RAPs over from M3 controllers to some newer 7220 controllers.  The RAPs work fine on the M3, but I canot get an IP address from the RAP pool when I connected it up to the 7220.  I think I am missing something small.
    Dec 31 00:22:06 :103063: <DBUG> |ike| get_ikev2_internal_ip pool Rap_pool
    Dec 31 00:22:06 :103061: <ERRS> |ike| Unable to get get IP Address from pool
    Bill
    #7220
  • 2.  RE: RAP not getting IP from RAP pool
    Posted Dec 31, 2014 11:01 AM
    Does each 7200 controller have a VPN address pool defined?
    Tim
  • 3.  RE: RAP not getting IP from RAP pool
    Posted Dec 31, 2014 11:05 AM
    Yes it does.  I have it defined as the same pool as the one on the M3.  I am using 172.16.10.11 - 172.16.10.20.
  • 4.  RE: RAP not getting IP from RAP pool
    Posted Dec 31, 2014 11:08 AM
    Please share the output of the following from the 7220.
    show vpdn l2tp local pool
    #7220
  • 5.  RE: RAP not getting IP from RAP pool
    Posted Dec 31, 2014 11:43 AM
    Here's the output.
    #show vpdn l2tp local pool
    IP addresses used in pool Rap_Pool
    none
    Total:-
    0 IPs used - 10 IPs free - 10 IPs configured
    IP pool allocations / de-allocations - L2TP: 0/0 IKE: 583/0
  • 6.  RE: RAP not getting IP from RAP pool
    Posted Dec 31, 2014 11:53 AM
    Are you assigning the L2TP pool name from the default RAP role?   It looks like from your log that it is looking for the pool named Rap_pool; but on your 7220 it is Rap_Pool.  Please delete the Rap_Pool on the 7220 and recreate as Rap_pool (case sensitive).
    #7220
  • 7.  RE: RAP not getting IP from RAP pool
    Posted Dec 31, 2014 12:45 PM
    That did the trick.  It was using the default RAP role.  l didn't realize the RAP pool definition was case sensitive.  All is connecting up fine.
    Thanks for the help.
  • 8.  RE: RAP not getting IP from RAP pool
    Posted Dec 31, 2014 01:09 PM
    quick question clembo.  Where do you find where the default profile that uses the IPSec address pool?
  • 9.  RE: RAP not getting IP from RAP pool
    Posted Dec 31, 2014 01:28 PM
    The RAPs are assigned a role by the controller.  For classic RAPs, it will use the system role ap-role.  If you specify an L2TP pool in that role, the RAPs will request an IP from that pool.   For RAP-NG, the default-vpn-role is used.
  • 10.  RE: RAP not getting IP from RAP pool
    Posted Dec 31, 2014 11:03 AM
    Do you have a pool named Rap_pool on the 7220?
    What is the output of:
    #7220
