"rap-operation always" but AP reboots when controller communication goes down
  • 1.  "rap-operation always" but AP reboots when controller communication goes down
    Posted Nov 22, 2013 01:14 PM
    [Running ArubaOS 6.2.1.4.]
    I'm looking at providing an SSID which works even when contact with the controller is lost.  I've set up a separate virtual AP with 'rap-operation always' and 'forward-mode bridge'.  This seems to do the trick: a few seconds after contact with the controller is lost, the SSIDs on tunneled virtual APs stop being advertised, but the bridged SSID one continues to function.
    However, after several minutes, the AP reboots to try and reestablish communication with the controller.  After it has completed rebooting, the bridged SSID resumes (and the tunnelled ones not), but then it dies again after about 10 minutes, when the AP reboots to find the controller again.  The result is the bridged SSID is unavailable periodically.
    Is there a way to stop the rebooting from happening?
    Finally, this behaviour is identical across CAPs and RAPs - I assume that when local bridging was added to CAPs (in ArubaOS 5.0, I think), this functionality was retained but the parameter continued to be called 'rap-operation'.
    Thanks in advance,
      - Bob
  • 2.  RE: "rap-operation always" but AP reboots when controller communication goes down
    Posted Nov 22, 2013 01:54 PM
    In the AP system profile, set IPSEC Retries to Zero and it will not go down.
    RAP-ALWAYS only pertains to RAPS and NOT CAPS.
  • 3.  RE: "rap-operation always" but AP reboots when controller communication goes down
    Posted Dec 04, 2013 01:43 PM
    Thanks for your help - for the IPsec retries, to you mean:
    ap system-profile "always-up_sys"
      number_ipsec_retries 0
    ... that doesn't seem to be working for me on either a RAP (or a CAP) -- once I take the VLAN on the upstream switch port away from the RAP, breaking the communication with the controller, the AP reboots after a few minutes.  The AP group has a VAP with 'rap-operation always' although something probably wasn't associated at the time (if that makes a difference).
    FWIW, the 'rap-operation always' seems to work fine for me on a CAP (with the reboot, but that's the same as a RAP), but I'm guessing this isn't supported or an undefined situation.
    In any case, it was only a query from one of our customers regarding RAPs vs CAPs and it isn't essential, so I'll leave the matter.
    Thanks for your help.
  • 4.  RE: "rap-operation always" but AP reboots when controller communication goes down
    Posted Dec 04, 2013 01:48 PM
    Is that SSID a PSK SSID?
  • 5.  RE: "rap-operation always" but AP reboots when controller communication goes down
    Posted Dec 05, 2013 06:06 AM
    Yes...
    wlan ssid-profile "hoppy_ssid"
       essid "hoppy"
       opmode wpa2-psk-aes
       wpa-passphrase e08c4184a65f3d18f40fc6e274c561c533692ef1157f3ecb
    wlan virtual-ap "hoppy_vap"
       aaa-profile "bridge-psk-noradius_aaa"
       vlan 499
       forward-mode bridge
    ap system-profile "mad-up_sys"
       lms-ip 131.111.1.9
       lms-preemption
    ap-group "cs-rnb_93h-aps"
       virtual-ap "lapwing-mad_vap"
       virtual-ap "eduroam-mad_vap"
       enet0-port-profile "ucs-rnb_wiredport"
       enet1-port-profile "ucs-rnb_wiredport"
       enet2-port-profile "ucs-rnb_wiredport"
       enet3-port-profile "ucs-rnb_wiredport"
       enet4-port-profile "ucs-rnb_wiredport"
       ap-system-profile "mad-up_sys"
  • 6.  RE: "rap-operation always" but AP reboots when controller communication goes down
    Posted 30 days ago
    Table 152: Remote AP Modes of Operation and Behavior
Remote AP
Operation
Setting
all
Forward Mode Setting
all
bridge
Management
frames on the AP.
Frames are
bridged between
wired and
wireless
interfaces.
No frames are
tunneled to the
Managed Device.
Station acquires
its IP address
locally from an
external DHCP
server.
split-tunnel
Management
frames on the AP.
Frames are either
GRE tunneled to
the Managed
Device, to a
trusted tunnel or
are sent through
the NAT and
bridged on the
wired interface
according to user
role and session
ACL
Typically, the
station obtains an
IP address from a
VLAN on the
Mobility Master.
tunnel
Frames al
tunneled
Managed
to an untr
tunnel.
100% ofs
frames ar
tunneled
Managed
    Remote AP
Operation
Setting
always
ESSID is always
up when the AP
is up
regardless of
whether the
Managed
Device is
reachable.
Supports PSK
ESSID only.
SSID
Provides an SSID
that is always
available for local
access.
Not supported
Not supp
    Remote AP
Operation
Setting
backup
persistent
ESSID is only up
when the
Managed
Device is
unreachable.
Supports PSK
ESSID only.
SSID
configuration
stored in flash
on AP.
ESSID is up
when the AP
contacts the
Managed
Device and
stays up if
connectivity is
disrupted with
the Managed
Provides a
backup SSID for
local access only
when the
Managed Device
is unreachable.
Same behavior
as standard,
described below,
except the ESSID
is up if
connectivity to
the Managed
Device is lost.
Not supported
Not supported
Not suppc
Not suppc
    standard
ESSID is up only
when there is
connectivity
with the
Managed
Device.
SSID
configuration
obtained from
Behaves like a
cla ssic Aruba
branch office AP.
Provides a
bridged ESSID
that is configured
from the
Managed Device
and stays up if
Split tunneling
mode
Classic Ar
thin AP OF
    If my post was useful, please Accept Solution and Give Kudos.
    leo ma
    ACMX
  • 7.  RE: "rap-operation always" but AP reboots when controller communication goes down
    Posted Mar 26, 2024 05:06 PM
    Hi, I´m Marcelo.  Excuse me, my English is very bad.  I know this post is old, but I have this situation now whit an Aruba 7205 WLC and AP515.  I have only one controller, so I configured bridge mode, AP remote al"always" and IPSEC Retries to Zero.
    I disconnect the WLC and the AP works during 20 minutes.  Then goes down and looks for the controller again.  What do you think about.  Could yo help me, please?  Thanks
  • 8.  RE: "rap-operation always" but AP reboots when controller communication goes down
    Posted 28 days ago
    As far as I know, you can set the IPSEC retries to the maximum (think it's 1000) and then you can get to a 1h20m reboot. If you want bridged SSIDs, converting your AP to Instant Mode may be an option.
