RAP over unstable network
  • 1.  RAP over unstable network
    Posted Apr 12, 2018 06:23 AM
    I recently installed RAP at a new office and unfroutantely the internet connection is not great. Doing a "show crypto isakmp sa" shows connections and hour or two old..
    I believe this is the cause of the headache experienced by users, so i did some tweaking to the config with "rap-operation persistent".
    Results are it works well when theres an outage, but when the data path comes back, it drops the network for around 10 seconds, then a further 4 seconds.
    THe test was by simply pinging 8.8.8.8
    Nothing facy with the setup, it is a simple bridge mode setup.
    Example config below -
    aaa profile "rap-default-dot1x-psk"
    initial-role "default-iap-user-role"
    mac-default-role "logon"
    authentication-dot1x "default-psk"
    wlan virtual-ap "test-rap"
    aaa-profile "rap-default-dot1x-psk"
    ssid-profile "test"
    forward-mode bridge
    wlan ssid-profile "test"
    essid "test"
    opmode wpa2-psk-aes
    a-basic-rates 12 24
    a-tx-rates 12 24 36 48 54
    g-basic-rates 12 24
    g-tx-rates 12 18 24 36 48 54
    wmm
    wmm-vo-dscp "46"
    wmm-vi-dscp "40"
    wmm-be-dscp "24"
    wmm-bk-dscp "8"
    local-probe-req-thresh 10
    wpa-passphrase ########
    max-tx-fail 3000
    mcast-rate-opt
    g-beacon-rate 24
    a-beacon-rate 24
    ap-group "Office"
    Is futher tweaking possible to minimise outage to end users?
  • 2.  RE: RAP over unstable network
    Posted Apr 26, 2018 08:32 PM
    Fixed this issue.
    Basically applied the following -
    ap system-profile "rap"
     bootstrap-threshold 30
    ap-group "Office"
     ap-system-profile "rap"
  • 3.  RE: RAP over unstable network
    Posted Apr 27, 2018 08:25 AM
    By default a RAPs bootstrap threshold *should be* 30 regardless of what is in the ap system profile.
