RAP provision problems - conversion successfully but failed at the next reboot to associate
  • 1.  RAP provision problems - conversion successfully but failed at the next reboot to associate
    Posted Sep 12, 2014 09:33 AM
    I have all tcp/udp ports opened from RAP to connect to controller on firewall.   RAP-3WN could be converted successfully and showed up on controller with status "down".
    If RAP is placed in the same LAN with controller,  it would boot up just fine and functional.  So I figure it is something to do with firewall but don't know what it is.
    Controller is 7210 vers 6.3.1.10.
    #7210
  • 2.  RE: RAP provision problems - conversion successfully but failed at the next reboot to associate
    Posted Sep 12, 2014 09:38 AM
    When it's attempting to connect, do you see any traffic when you run:
    show datapath session table | include 4500
  • 3.  RE: RAP provision problems - conversion successfully but failed at the next reboot to associate
    Posted Sep 12, 2014 10:04 AM
    Thanks for the help.
    It showed up for a few seconds but disappeared from session table.
    205.211.168.200 is RAP IP.  10.1.100.16 is the master IP and 10.1.100.17 is the local.
    Aruba-Master-A) #show datapath session table | include 4500
    10.1.100.17     10.1.100.16     17   4500  4500   0/0     0 0   0   0/0/0       2b   7         1592       FC
    10.1.100.16     10.1.100.17     17   4500  4500   0/0     0 0   1   0/0/0       2b   0         0          F
    10.1.100.16     205.211.168.200 17   4500  32768  0/0     0 0   0   local       7    1         108        FDC
    The following is firewall traffic log: 205.211.168.200 is RAP, 205.211.168.9 is public IP for master controller.
    85.387941 arp who-has 205.211.168.9 tell 205.211.168.200
    85.387950 arp reply 205.211.168.9 is-at 0:9:f:9:0:17
    85.388198 205.211.168.200.32768 -> 205.211.168.9.4500: udp 390
    85.390405 205.211.168.9.4500 -> 205.211.168.200.32768: udp 60
    85.393347 205.211.168.200.32768 -> 205.211.168.9.4500: udp 418
    85.396310 205.211.168.9.4500 -> 205.211.168.200.32768: udp 417
    90.056041 arp who-has 205.211.168.200 tell 205.211.168.3
    90.386191 arp who-has 205.211.168.200 tell 205.211.168.38
    90.386826 arp reply 205.211.168.200 is-at 0:9:f:30:16:ba
    107.168881 205.211.168.200 -> 205.211.168.9: icmp: 205.211.168.200 udp port 32768 unreachable
    107.168910 205.211.168.200 -> 205.211.168.9: icmp: 205.211.168.200 udp port 32768 unreachable
    119.189696 205.211.168.200 -> 205.211.168.9: icmp: 205.211.168.200 udp port 32768 unreachable
    119.189942 205.211.168.200 -> 205.211.168.9: icmp: 205.211.168.200 udp port 32768 unreachable
    Yong
  • 4.  RE: RAP provision problems - conversion successfully but failed at the next reboot to associate
    Posted Sep 12, 2014 09:48 AM
    You'll also need to open IP protocol 50 for IPSec.
  • 5.  RE: RAP provision problems - conversion successfully but failed at the next reboot to associate
    Posted Sep 12, 2014 10:43 AM
    The fact that it can connect and function on the LAN indicates either a firewall or routing issue.   You've ruled out the firewall issue by opening all ports as you have indicated (you only really need UDP 4500).
    My guess is it is a routing issue.  What is the default route of the controller?   Is it the external firewall or something on the inside?   If your controller is terminating RAPs from the Internet, it's default gateway needs to be the next external hop (your firewall doing the external NAT usually).   Otherwise you'll end up in an asynchronous routing issue where traffic comes in one way but the response goes another.
    You can then add static routes as necessary for any internal networks.
  • 6.  RE: RAP provision problems - conversion successfully but failed at the next reboot to associate
    Posted Sep 12, 2014 11:31 AM
    Thanks clembo.   I think that is the most possible cause right now.  The master controll doesn't have internet connectivity as it is blocked by ACL.  I will test it.
    Question: does controller initiate any connection to AP?
    Yong
  • 7.  RE: RAP provision problems - conversion successfully but failed at the next reboot to associate
    Posted Sep 12, 2014 01:00 PM
    All communication from the controller is within the IPsec tunnel; so the only firewall rule you'll need to add is UDP 4500 to the controller from the Internet side.   And then make sure the controller uses this same path as its default route.
  • 8.  RE: RAP provision problems - conversion successfully but failed at the next reboot to associate
    Posted Oct 24, 2014 03:59 PM
    Thanks again clembo.  It was routing issue.  Everything is good now.
