I pre-provisioned a RAP2 device and I want to see the IP address parameters I setup on it when I provisioned it. The Rap is not currently online but I want to see what I saved when I provisioned it. How can I do that from the CLI?
Thanks, Tony
You can do show ap database | include <name of the rap> and it should show up on the down list with the ip address it was setup if it came up or you can do show audit-trail and you can see the changes you made
Well, I did not get any returned data on the first command but the ah audit-trail did the trick.
Thank you kindly.
