RAP Split-tunnel - Vlan User traffic
  • 1.  RAP Split-tunnel - Vlan User traffic
    Posted Jun 14, 2022 06:01 AM
    I have an AP in RAP (Split-tunnel mode) and i have a Wlan Guest with a captive portal local to the controller.
    The controller makes dhcp server.
    Non-corporate customer traffic is sourced locally with the Default Guest Role after Authenticated on the Captive Portal:
    Policy after authenticated:
    Policy: any any dhcp permit
    Policy: user dc dns permit
    Policy: user controller http dst-nat 8080
    Policy: user circusnetwork any deny
    Policy: user any any route src-nat
    My problem:
    The User traffic goes through the vlan "management (500)" of the AP and not in the vlan "Guest (2000)"
    My question:
    Can this be changed ?
    Thank you in advance
  • 2.  RE: RAP Split-tunnel - Vlan User traffic
    Posted Jun 14, 2022 06:36 AM
    the last acl should be "any any any permit"  The traffic that is routed and source natted goes AP VLAN, which is what the last ACL does.
  • 3.  RE: RAP Split-tunnel - Vlan User traffic
    Posted Jun 14, 2022 08:21 AM
    Thanks for your response,
    If I remove the "src-nat route", the traffic will not be routed locally  and will go to the controller ?
  • 4.  RE: RAP Split-tunnel - Vlan User traffic
    Posted Jun 14, 2022 11:20 AM
    If you remove the last rule, the traffic will be blocked.
    If you do an allow all as the last rule, the traffic will be tunneled back to the controller.
    A rule with "route src-nat" will be source natted out of the ip address of the AP.
