RAP upstream speed problem with cellular modem
  • 1.  RAP upstream speed problem with cellular modem
    Posted Feb 06, 2015 01:27 PM
    I have tested rap ap with 4G cellular modem uplink and maximum speed I have received for uptream has been 4Mbps. Downstream speed has rolled around 20-30Mbps. I tested my cellular modem without Aruba ap and then I get 30Mbps for downtream and 25Mbps for uptream so the proplem is not in my cellular modem connection. I have done test with cat-cabel and via wifi, results are same. I did test with different ap models rap-155 and rap-109, results were same kind with both models. Only difference was that with rap-109 I received 20Mbps downstream and with rap-155 downstream speed were 30Mbps. This upstream speed problem occurs only with cellular modems, my other rap-ap:s works fine.
    Has anyone run into same proplem? Is it feature or some limitation in ipsec tunnel? Latency in cellular connection is around 40ms, could it effect to this? But if so why downstream speed is good...
  • 2.  RE: RAP upstream speed problem with cellular modem
    MVP GURU
    Posted Feb 09, 2015 04:53 AM
    May be a limitation by your cellelular operator about IPsec stream ?
  • 3.  RE: RAP upstream speed problem with cellular modem
    Posted Feb 09, 2015 06:23 AM
    Hi and thanks for reply.
    I asked this from cellular operator and they dont have limitations for ipsec traffic. I was thinking could this be udp window size problem?
  • 4.  RE: RAP upstream speed problem with cellular modem
    MVP GURU
    Posted Feb 09, 2015 06:24 AM
    May be
    Do you have try to capture traffic ?
  • 5.  RE: RAP upstream speed problem with cellular modem
    Posted Feb 11, 2015 12:21 AM
    What USB settings were used when provisioning the AP?
  • 6.  RE: RAP upstream speed problem with cellular modem
    Posted Feb 11, 2015 07:43 AM
    here's current usb config from my test-rap.
    USB User Name xxxxx
    USB Password xxxxx
    USB Device Type option
    USB Device Identifier 0x19d21428
    USB Dial String ATD*99#
    USB Initialization String AT+cgcont=1,\"ip\",\"internet\"
    USB TTY device data path ttyUSB1
    USB TTY device control path N/A
    USB modeswitch parameters N/A
    Uplink VLAN 0
    Remote AP Yes
    Link Priority Ethernet 110
    Link Priority Cellular 90
    Cellular modem network preference auto
    USB power mode enable
