RAP whitelist not showing?
  • 1.  RAP whitelist not showing?
    MVP
    Posted Jan 27, 2012 06:23 AM
    Doing a new controller install here (M3mk1 with 6.1.2.7) and I'm missing the Remote AP whitelist screen from the Configuration -> AP Installation menu. The tab is simply not there. Cleared my browsers cache without result.
    Any idea's where its gone? Is a license required for it?
  • 2.  RE: RAP whitelist not showing?
    Posted Jan 27, 2012 06:28 AM
    There should be no licenses required for it.  Do you have any licenses on the controller, at all?
  • 3.  RE: RAP whitelist not showing?
    MVP
    Posted Jan 27, 2012 06:30 AM
    found my issue, you DO need licenses.. AP licenses or it simply does not show up apparently.
  • 4.  RE: RAP whitelist not showing?
    Posted Jan 27, 2012 06:31 AM
    Thank you for confirming that.
