we have a bunch of RAPs (303H) as Wired "Router" for small branches (50-100M internet). Is there any chance to display those traffic in the controller Gui ? Currently it is very hard to find out whats up on the wired port and whats up with the users behind them. I know that sdwan faces those "black holes" but currently iam in a rap design with 20% of wireless and 80% of wired "tunneld" traffic and currently i didn't see them in apprf and in bandwith. Is there anyone who fixed this missing display features on the wired port?
Thanks in advance
You would make those ports "untrusted" and make the initial role of the AAA profile applied to that port have an "allowall" acl, so no traffic is blocked. Users on wired ports will appear as users in the controller and you will be able to see their traffic.
you are right. The traffic is currently "bypassing" the firewall and the apprf with the hook "trusted". So untrust and combined with a policy it pops up in apprf! -> Tested and solved!
Thanks for that fast answer on this
