I havs several RAP with IPsec down status.
The controller process log shows a lot of messages
Aug 7 07:31:40 isakmpd[1496]: <103060> <DBUG> |ike| 125.XXX.XXX.87:4500-> ike_phase_1.c:attribute_unacceptable:2685 Proposal match failed in encryption algo, configured=AES_CBC, peer using=3DES_CBC
Aug 7 07:31:40 isakmpd[1496]: <103060> <DBUG> |ike| 125.XXX.XXX.87:4500-> ike_phase_1.c:attribute_unacceptable:2711 Proposal match failed in auth algo, configured=RSA_SIG, peer using=unknown
below is my crypto configuration,
please give me a hint,
Thank you !
crypto isakmp policy 20
encryption aes256
crypto isakmp key "a6ee1490ac869fadc7941630cd7d70df47673fb7cc2f8d7f" address 0.0.0.0 netmask 0.0.0.0
crypto ipsec transform-set default-boc-bm-transform esp-3des esp-sha-hmac
crypto ipsec transform-set default-rap-transform esp-aes256 esp-sha-hmac
crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
crypto dynamic-map default-dynamicmap 10000
set transform-set "default-transform" "default-aes"
no crypto-local isakmp xauth
crypto isakmp eap-passthrough eap-tls
crypto isakmp eap-passthrough eap-peap
crypto isakmp eap-passthrough eap-mschapv2
