RAP Zero Touch over IPv6 Ds-Lite ISP
  • 1.  RAP Zero Touch over IPv6 Ds-Lite ISP
    Posted Jan 28, 2016 03:15 AM
    Does anyone have any scenarios where RAP are installed on Internet providers using IPv6 Dual Stack?
    I want to know wthether or not there is any incompatyibility or caveat using the current IPv4 Aruba Zero Touch provision method in these type of implementatioon.
  • 2.  RE: RAP Zero Touch over IPv6 Ds-Lite ISP
    Posted Jan 28, 2016 04:55 AM
    We have quite a few installations on these types of networks.  There is always a chance that something could go wrong though.  Are you having any issues?
  • 3.  RE: RAP Zero Touch over IPv6 Ds-Lite ISP
    Posted Jan 28, 2016 05:19 AM
    No yet but I see more and more home users in US with Comcast and in EU with Cablecom and the same IPv6 Lite version and I'm about to roll out more in UK. I don't want to have surprises.
    In the past I had some issues with SSL/VPN from Cablecom.
  • 4.  RE: RAP Zero Touch over IPv6 Ds-Lite ISP
    Posted Jan 28, 2016 05:59 AM
    I think that as soon as you identify a user that has that setup, you should get a RAP to them so that if there are any issues they can be observed, analyzed and fixed.
  • 5.  RE: RAP Zero Touch over IPv6 Ds-Lite ISP
    Posted Jan 28, 2016 06:22 AM
    Will do, thanks for your inputs.  Do you know if there is any plan to support Zero touch provisioning for RAP on IPv6?
  • 6.  RE: RAP Zero Touch over IPv6 Ds-Lite ISP
    Posted Jan 28, 2016 07:27 AM
    I do not know of any plans, personally, no.
