RAP155 convert faild | log output: IKE SA failed reason = ERR_IKE_TIMEOUT, errorcode = -8949 ikeVer
  • 1.  RAP155 convert faild | log output: IKE SA failed reason = ERR_IKE_TIMEOUT, errorcode = -8949 ikeVer
    Posted Dec 26, 2015 09:52 PM
    Hi aireads,
    Im encouter strange issues when trying to convert RAP-155 unit to work as a RAP (from IAP mode) , here is the output: (From the IAP log after the failed convert process)
    This is the only error that repating itself:
    Target : 00:0b:86:9d:a7:38
    show vpn status
    profile name:default
    current using tunnel                            :unselected tunnel
    ipsec is preempt status                         :disable
    ipsec is fast failover status                   :disable
    ipsec hold on period                            :600
    ipsec tunnel monitor frequency (seconds/packet) :5
    ipsec tunnel monitor timeout by lost packet cnt :6
    ipsec     primary tunnel crypto type            :Cert
    ipsec     primary tunnel peer address           :***.***.***.***
    ipsec     primary tunnel peer tunnel ip         :0.0.0.0
    ipsec     primary tunnel ap tunnel ip           :0.0.0.0
    ipsec     primary tunnel current sm status      :Retrying
    ipsec     primary tunnel tunnel status          :Down
    ipsec     primary tunnel tunnel retry times     :3
    ipsec     primary tunnel tunnel uptime          :0
    ipsec      backup tunnel crypto type            :Cert
    ipsec      backup tunnel peer address           :N/A
    ipsec      backup tunnel peer tunnel ip         :N/A
    ipsec      backup tunnel ap tunnel ip           :N/A
    ipsec      backup tunnel current sm status      :Init
    ipsec      backup tunnel tunnel status          :Down
    ipsec      backup tunnel tunnel retry times     :0
    ipsec      backup tunnel tunnel uptime          :0
    end of show vpn status
    show upgrade info
    Image Upgrade Progress
    Mac                IP Address  AP Class  Status    Image Info  Error Detail
    00:0b:86:9d:a7:38  10.0.0.1    Aries     image-ok  image file  none
    Auto reboot           :enable
    Use external URL      :enable
    end of show upgrade info
    show log upgrade
    ----------Download log start----------
    download log not available
    ----------Download log end------------
    Download status: incomplete
    ----------Upgrade log start----------
    upgrade log not available
    ----------Upgrade log end------------
    Upgrade status: upgrade status not available
    end of show log upgrade
    show log rapper
    EC_generateKey_FIPS_consistancy_test: GOOD Signature Verify!
    Dec 24, 13:42:27: main: ethmacstr = 00:0B:86:9D:A7:38
    Dec 24, 13:42:27: main(): Entered, getpid()=3913
    Dec 24, 13:42:27: get_ike_version: Use IKE Version 2
    Dec 24, 13:42:27: papi_init papifd:8  ack:14
    IKE_EXAMPLE: Starting up IKE server
    setup_tunnel
    Dec 24, 13:42:27: IKE_init: ethmacstr = 00:0B:86:9D:A7:38
    Initialized Timers
    IKE_init: completed after (0.0)(pid:3913)  time:2015-12-24 13:42:27
     seconds.
    Dec 24, 13:42:27: RAP using default certificates
    Dec 24, 13:42:27: Before getting Certs
    Dec 24, 13:42:27: TPM enabled
    Dec 24, 13:42:27: get_usb_type: Unable to open /tmp/usb_type
    Dec 24, 13:42:27: get_usb_csr: Unable to open /tmp/usb_csr
    Dec 24, 13:42:27: CA_MGMT_EXAMPLE_computeHostKeys init cert-len 0
    Dec 24, 13:42:27: Factory Device Cert is /tmp/deviceCerts/certifiedKeyCert.der
    Dec 24, 13:42:27: Reading DER Device Cert file /tmp/deviceCerts/certifiedKeyCert.der
    Dec 24, 13:42:27: DER Device Cert file len:1767
    Dec 24, 13:42:27: Intermediate Cert index:0 is /tmp/deviceCerts/certifiedKeyCaCert.der
    Dec 24, 13:42:27: Reading DER Intermediate Cert file
    Dec 24, 13:42:27: DER Intermediate Cert file len:1456
    Dec 24, 13:42:27: Intermediate Cert index:1 is /tmp/deviceCerts/caChainCert1.der
    Dec 24, 13:42:27: DER Intermediate Cert file len:1580
    Dec 24, 13:42:27: Decode PEM Key length :0
    Dec 24, 13:42:27: testHostKeys : status 0
    Dec 24, 13:42:27: testHostKeys : free temp Certificate status 0
    Dec 24, 13:42:27: CA_MGMT_EXAMPLE_computeHostKeys after testHostKeys cert-len 1767
    Dec 24, 13:42:27: CA Cert index:0 is /tmp/deviceCerts/OpensslOldCA_RootCert.der
    Dec 24, 13:42:27: Reading DER CA Cert file
    Dec 24, 13:42:27: DER CA Cert file len:1416
    Dec 24, 13:42:27: CA Cert index:1 is /tmp/deviceCerts/MSCAV1_RootCert.der
    Dec 24, 13:42:27: DER CA Cert file len:1009
    Dec 24, 13:42:27: Got 2 Trusted Certs
    Dec 24, 13:42:27: After getFieldTrustedCerts ret:-1
    Dec 24, 13:42:27: Got 0 Field Trusted Certs
    Dec 24, 13:42:27: CSS CA Cert is /tmp/deviceCerts/CSS_CA_RootCert.der
    Dec 24, 13:42:27: Error in reading DER CA Cert:/tmp/deviceCerts/CSS_CA_RootCert.der, Ignore It
    Dec 24, 13:42:27: CA Cert status : 0
    Before IKE_initServer
    Dec 24, 13:42:27: IKE_initServer: Cert length 1767
    IKE_initServer: Host Certificate is set (RSA-SIG)
      {CN=CC0010126::00:0b:86:9d:a7:38}
    Dec 24, 13:42:27: IKE_EXAMPLE_addServer port:0 natt:0
    Dec 24, 13:42:27: srcdev_name = br0 ip a000001
    Dec 24, 13:42:27: IKE_EXAMPLE_addUdpSkt: Using SocketIndex:0
    IKE_EXAMPLE: Socket created on 10.0.0.1[0]
    Dec 24, 13:42:27: IKE_EXAMPLE_addServer:1333 socket descriptor  is 0 port number 50696 for server instance 0 at 0th index
    Dec 24, 13:42:27: IKE_EXAMPLE_addUdpSkt: Using SocketIndex:1
    IKE_EXAMPLE: Socket created on 10.0.0.1[50697]
    Dec 24, 13:42:27: IKE_EXAMPLE_addServer:1380 socket descriptor  is 1 port number 50697 for server instance 0 at 1st index
    Dec 24, 13:42:27: IKE_EXAMPLE_addDefaultServers status:0
     SA_INIT dest=193.43.247.77
    Dec 24, 13:42:27:  Initialize IKE SA
    Dec 24, 13:42:27: IKE_CUSTOM_getVersion(peerAddr:c12bf74d): ikeVersion:2
    Timer ID: 1 Initialized
    Dec 24, 13:42:27: IKE2_newSa(peerAddr:c12bf74d): IKE_SA-lifetime:28000
      I -->
    Dec 24, 13:42:27: OutSa(v2-peerAddr:0 pxSa->dwPeerAddr:c12bf74d): Entered
         ENCR_AES 256-BITS
         PRF_HMAC_SHA1
         AUTH_HMAC_SHA1_96
         DH_2
       NAT_D (us): 8e 08 f5 10 8d 4a f1 a2 6f 2c 9f 8e d0 e4 7d 1c
    15 b4 1f 4b
       NAT_D (peer): b6 f6 ed b4 6d 4d 6f 48 9b 69 46 9b 9d 42 07 cf
    84 79 4c 51
    Dec 24, 13:42:27: RAPPER_ERROR_FILE doesn't exist
     spi={7a3a018bb0a6a390 0000000000000000} np=SA
     exchange=IKE_SA_INIT msgid=0 len=380
    #SEND 384 bytes to 193.43.247.77[4500] (0.0)(pid:3913)  time:2015-12-24 13:42:27
    Dec 24, 13:42:27: IKE_SAMPLE_ikeXchgSend Successfully setsockopt UDP_ENCAP port 50697
    IKE_EXAMPLE: IKE_keyConnect() started, id = 0xDec 24, 13:42:27: IKE_EXAMPLE: IKE_keyConnect() started, id = 0x on device br0
    c6d5641d...
    Dec 24, 13:42:27: papi:15200
    #SEND 384 bytes to 193.43.247.77[4500] (5.0)(pid:3913)  time:2015-12-24 13:42:33
    #SEND 384 bytes to 193.43.247.77[4500] (11.0)(pid:3913)  time:2015-12-24 13:42:38
    #SEND 384 bytes to 193.43.247.77[4500] (16.0)(pid:3913)  time:2015-12-24 13:42:43
    Dec 24, 13:42:48: IKE_checkExpSa rekey notfinished timeout 21000 sec
    Dec 24, 13:42:48: IKE_SAMPLE_ikeStatHdlr(CHILD_SA): dwPeerAddr:c12bf74d index:0 mPeerType:0
    Dec 24, 13:42:48: IKE SA failed reason = ERR_IKE_TIMEOUT, errorcode = -8949 ikeVer 2
    Dec 24, 13:42:48: send_sapd_error: InnerIP:0  error:43 debug_error:-8949
    Dec 24, 13:42:48: send_sapd_error: error:43 debug_error:-8949
    Dec 24, 13:42:48: rapper_log_error: buf = 7a 3a 01 8b b0 a6 a3 90 2b
    Dec 24, 13:42:48: IKE_SAMPLE_ikeStatHdlr(SA): dwPeerAddr:c12bf74d index:0 mPeerType:0
    Dec 24, 13:42:48: IKE_SA [v2 I] (id=0xc6d5641d) flags 0x41000005 failed reason = ERR_IKE_TIMEOUT, errorcode = -8949
    Dec 24, 13:42:48: IKE_SAMPLE_ikeStatHdlr(IST_FAIL): g_ikeversion:2
    Timer ID: 1 Deleted
    rapperSendStatusCB
    Dec 24, 13:42:58: main: ethmacstr = 00:0B:86:9D:A7:38
    Dec 24, 13:42:58: main(): Entered, getpid()=4062
    Dec 24, 13:42:58: get_ike_version: Use IKE Version 2
    Dec 24, 13:42:58: papi_init papifd:8  ack:14
    setup_tunnel
    Dec 24, 13:42:58: IKE_init: ethmacstr = 00:0B:86:9D:A7:38
    Initialized Timers
    IKE_init: completed after (0.0)(pid:4062)  time:2015-12-24 13:42:58
     seconds.
    Dec 24, 13:42:58: RAP using default certificates
    Dec 24, 13:42:58: Before getting Certs
    Dec 24, 13:42:58: TPM enabled
    Dec 24, 13:42:58: get_usb_type: Unable to open /tmp/usb_type
    Dec 24, 13:42:58: get_usb_csr: Unable to open /tmp/usb_csr
    Dec 24, 13:42:58: CA_MGMT_EXAMPLE_computeHostKeys init cert-len 0
    Dec 24, 13:42:58: Factory Device Cert is /tmp/deviceCerts/certifiedKeyCert.der
    Dec 24, 13:42:58: Reading DER Device Cert file /tmp/deviceCerts/certifiedKeyCert.der
    Dec 24, 13:42:58: DER Device Cert file len:1767
    Dec 24, 13:42:58: Intermediate Cert index:0 is /tmp/deviceCerts/certifiedKeyCaCert.der
    Dec 24, 13:42:58: Reading DER Intermediate Cert file
    Dec 24, 13:42:58: DER Intermediate Cert file len:1456
    Dec 24, 13:42:58: Intermediate Cert index:1 is /tmp/deviceCerts/caChainCert1.der
    Dec 24, 13:42:58: DER Intermediate Cert file len:1580
    Dec 24, 13:42:58: Decode PEM Key length :0
    Dec 24, 13:42:58: testHostKeys : status 0
    Dec 24, 13:42:58: testHostKeys : free temp Certificate status 0
    Dec 24, 13:42:58: CA_MGMT_EXAMPLE_computeHostKeys after testHostKeys cert-len 1767
    Dec 24, 13:42:58: CA Cert index:0 is /tmp/deviceCerts/OpensslOldCA_RootCert.der
    Dec 24, 13:42:58: Reading DER CA Cert file
    Dec 24, 13:42:58: DER CA Cert file len:1416
    Dec 24, 13:42:58: CA Cert index:1 is /tmp/deviceCerts/MSCAV1_RootCert.der
    Dec 24, 13:42:58: DER CA Cert file len:1009
    Dec 24, 13:42:58: Got 2 Trusted Certs
    Dec 24, 13:42:58: After getFieldTrustedCerts ret:-1
    Dec 24, 13:42:58: Got 0 Field Trusted Certs
    Dec 24, 13:42:58: CSS CA Cert is /tmp/deviceCerts/CSS_CA_RootCert.der
    Dec 24, 13:42:58: Error in reading DER CA Cert:/tmp/deviceCerts/CSS_CA_RootCert.der, Ignore It
    Dec 24, 13:42:58: CA Cert status : 0
    Dec 24, 13:42:58: IKE_initServer: Cert length 1767
    Dec 24, 13:42:58: IKE_EXAMPLE_addServer port:0 natt:0
    Dec 24, 13:42:58: srcdev_name = br0 ip a000001
    Dec 24, 13:42:58: IKE_EXAMPLE_addUdpSkt: Using SocketIndex:0
    IKE_EXAMPLE: Socket created on 10.0.0.1[50698]
    Dec 24, 13:42:58: IKE_EXAMPLE_addServer:1333 socket descriptor  is 0 port number 50698 for server instance 0 at 0th index
    Dec 24, 13:42:58: IKE_EXAMPLE_addUdpSkt: Using SocketIndex:1
    IKE_EXAMPLE: Socket created on 10.0.0.1[50699]
    Dec 24, 13:42:58: IKE_EXAMPLE_addServer:1380 socket descriptor  is 1 port number 50699 for server instance 0 at 1st index
    Dec 24, 13:42:58: IKE_EXAMPLE_addDefaultServers status:0
    Dec 24, 13:42:58:  Initialize IKE SA
    Dec 24, 13:42:58: IKE_CUSTOM_getVersion(peerAddr:c12bf74d): ikeVersion:2
    Dec 24, 13:42:58: IKE2_newSa(peerAddr:c12bf74d): IKE_SA-lifetime:28000
      I -->
    Dec 24, 13:42:58: OutSa(v2-peerAddr:0 pxSa->dwPeerAddr:c12bf74d): Entered
         ENCR_AES 256-BITS
         PRF_HMAC_SHA1
         AUTH_HMAC_SHA1_96
         DH_2
       NAT_D (us): 56 4c b3 4c de 21 0c 7c 6d d6 24 3b 5f c1 6d 98
    ee bc 88 7b
       NAT_D (peer): 68 36 ea 71 25 9f d0 6a d8 79 3e 6d 75 42 8b 49
    74 8f f4 4e
    Dec 24, 13:42:58: RAPPER_ERROR_FILE exists
    Dec 24, 13:42:58: AP err cookie retval 9 cookie:7a3a018bb0a6a390 err 2b
     spi={377b329e03f9dafe 0000000000000000} np=SA
    #SEND 384 bytes to 193.43.247.77[4500] (0.0)(pid:4062)  time:2015-12-24 13:42:58
    Dec 24, 13:42:58: IKE_SAMPLE_ikeXchgSend Successfully setsockopt UDP_ENCAP port 50699
    IKE_EXAMPLE: IKE_keyConnect() started, id = 0xDec 24, 13:42:58: IKE_EXAMPLE: IKE_keyConnect() started, id = 0x on device br0
    c6b63137...
    Dec 24, 13:42:58: papi:15200
    #SEND 384 bytes to 193.43.247.77[4500] (5.0)(pid:4062)  time:2015-12-24 13:43:03
    #SEND 384 bytes to 193.43.247.77[4500] (10.0)(pid:4062)  time:2015-12-24 13:43:09
    #SEND 384 bytes to 193.43.247.77[4500] (15.0)(pid:4062)  time:2015-12-24 13:43:14
    Dec 24, 13:43:19: IKE_checkExpSa rekey notfinished timeout 21000 sec
    Dec 24, 13:43:19: IKE_SAMPLE_ikeStatHdlr(CHILD_SA): dwPeerAddr:c12bf74d index:0 mPeerType:0
    Dec 24, 13:43:19: IKE SA failed reason = ERR_IKE_TIMEOUT, errorcode = -8949 ikeVer 2
    Dec 24, 13:43:19: send_sapd_error: InnerIP:0  error:43 debug_error:-8949
    Dec 24, 13:43:19: send_sapd_error: error:43 debug_error:-8949
    Dec 24, 13:43:19: rapper_log_error: buf = 37 7b 32 9e 03 f9 da fe 2b
    Dec 24, 13:43:19: IKE_SAMPLE_ikeStatHdlr(SA): dwPeerAddr:c12bf74d index:0 mPeerType:0
    Dec 24, 13:43:19: IKE_SA [v2 I] (id=0xc6b63137) flags 0x41000005 failed reason = ERR_IKE_TIMEOUT, errorcode = -8949
    Dec 24, 13:43:19: IKE_SAMPLE_ikeStatHdlr(IST_FAIL): g_ikeversion:2
    Timer ID: 1 Deleted
    rapperSendStatusCB
    Dec 24, 13:43:29: main: ethmacstr = 00:0B:86:9D:A7:38
    Dec 24, 13:43:29: main(): Entered, getpid()=4267
    Dec 24, 13:43:29: get_ike_version: Use IKE Version 2
    Dec 24, 13:43:29: papi_init papifd:8  ack:14
    setup_tunnel
    Dec 24, 13:43:29: IKE_init: ethmacstr = 00:0B:86:9D:A7:38
    Initialized Timers
    IKE_init: completed after (0.0)(pid:4267)  time:2015-12-24 13:43:29
     seconds.
    Dec 24, 13:43:29: RAP using default certificates
    Dec 24, 13:43:29: Before getting Certs
    Dec 24, 13:43:29: TPM enabled
    Dec 24, 13:43:29: get_usb_type: Unable to open /tmp/usb_type
    Dec 24, 13:43:29: get_usb_csr: Unable to open /tmp/usb_csr
    Dec 24, 13:43:29: CA_MGMT_EXAMPLE_computeHostKeys init cert-len 0
    Dec 24, 13:43:29: Factory Device Cert is /tmp/deviceCerts/certifiedKeyCert.der
    Dec 24, 13:43:29: Reading DER Device Cert file /tmp/deviceCerts/certifiedKeyCert.der
    Dec 24, 13:43:29: DER Device Cert file len:1767
    Dec 24, 13:43:29: Intermediate Cert index:0 is /tmp/deviceCerts/certifiedKeyCaCert.der
    Dec 24, 13:43:29: Reading DER Intermediate Cert file
    Dec 24, 13:43:29: DER Intermediate Cert file len:1456
    Dec 24, 13:43:29: Intermediate Cert index:1 is /tmp/deviceCerts/caChainCert1.der
    Dec 24, 13:43:29: DER Intermediate Cert file len:1580
    Dec 24, 13:43:29: Decode PEM Key length :0
    Dec 24, 13:43:29: testHostKeys : status 0
    Dec 24, 13:43:29: testHostKeys : free temp Certificate status 0
    Dec 24, 13:43:29: CA_MGMT_EXAMPLE_computeHostKeys after testHostKeys cert-len 1767
    Dec 24, 13:43:29: CA Cert index:0 is /tmp/deviceCerts/OpensslOldCA_RootCert.der
    Dec 24, 13:43:29: Reading DER CA Cert file
    Dec 24, 13:43:29: DER CA Cert file len:1416
    Dec 24, 13:43:29: CA Cert index:1 is /tmp/deviceCerts/MSCAV1_RootCert.der
    Dec 24, 13:43:29: DER CA Cert file len:1009
    Dec 24, 13:43:29: Got 2 Trusted Certs
    Dec 24, 13:43:29: After getFieldTrustedCerts ret:-1
    Dec 24, 13:43:29: Got 0 Field Trusted Certs
    Dec 24, 13:43:29: CSS CA Cert is /tmp/deviceCerts/CSS_CA_RootCert.der
    Dec 24, 13:43:29: Error in reading DER CA Cert:/tmp/deviceCerts/CSS_CA_RootCert.der, Ignore It
    Dec 24, 13:43:29: CA Cert status : 0
    Dec 24, 13:43:29: IKE_initServer: Cert length 1767
    Dec 24, 13:43:29: IKE_EXAMPLE_addServer port:0 natt:0
    Dec 24, 13:43:29: srcdev_name = br0 ip a000001
    Dec 24, 13:43:29: IKE_EXAMPLE_addUdpSkt: Using SocketIndex:0
    IKE_EXAMPLE: Socket created on 10.0.0.1[50700]
    Dec 24, 13:43:29: IKE_EXAMPLE_addServer:1333 socket descriptor  is 0 port number 50700 for server instance 0 at 0th index
    Dec 24, 13:43:29: IKE_EXAMPLE_addUdpSkt: Using SocketIndex:1
    IKE_EXAMPLE: Socket created on 10.0.0.1[50701]
    Dec 24, 13:43:29: IKE_EXAMPLE_addServer:1380 socket descriptor  is 1 port number 50701 for server instance 0 at 1st index
    Dec 24, 13:43:29: IKE_EXAMPLE_addDefaultServers status:0
    Dec 24, 13:43:29:  Initialize IKE SA
    Dec 24, 13:43:29: IKE_CUSTOM_getVersion(peerAddr:c12bf74d): ikeVersion:2
    Dec 24, 13:43:29: IKE2_newSa(peerAddr:c12bf74d): IKE_SA-lifetime:28000
      I -->
    Dec 24, 13:43:29: OutSa(v2-peerAddr:0 pxSa->dwPeerAddr:c12bf74d): Entered
         ENCR_AES 256-BITS
         PRF_HMAC_SHA1
         AUTH_HMAC_SHA1_96
         DH_2
       NAT_D (us): 23 21 cb 08 60 3c c2 6f a2 bf af 49 ab ca da 5d
    6e df c3 0c
       NAT_D (peer): 6b cc ee f0 fe 1d 58 0b 3d b1 dc 05 10 7c 8c 40
    d0 6c 53 7e
    Dec 24, 13:43:29: RAPPER_ERROR_FILE exists
    Dec 24, 13:43:29: AP err cookie retval 9 cookie:377b329e03f9dafe err 2b
     spi={a509548d1be1f638 0000000000000000} np=SA
    #SEND 384 bytes to 193.43.247.77[4500] (0.0)(pid:4267)  time:2015-12-24 13:43:29
    Dec 24, 13:43:29: IKE_SAMPLE_ikeXchgSend Successfully setsockopt UDP_ENCAP port 50701
    IKE_EXAMPLE: IKE_keyConnect() started, id = 0xDec 24, 13:43:29: IKE_EXAMPLE: IKE_keyConnect() started, id = 0x on device br0
    bb7ecabd...
    Dec 24, 13:43:29: papi:15200
    end of show log rapper
    ========================================================g
  • 2.  RE: RAP155 convert faild | log output: IKE SA failed reason = ERR_IKE_TIMEOUT, errorcode = -8949 ikeVer
    Posted Dec 27, 2015 12:21 AM
    Enable debugging on the controller:
    config t
    logging level debugging security subcat ike
    logging level debugging security process aaa
    logging level debugging security process authmgr
    logging level debugging security subcat l2tp
    logging level debugging security subcat vpn
    Type "show log security 50" when you are trying to convert.
  • 3.  RE: RAP155 convert faild | log output: IKE SA failed reason = ERR_IKE_TIMEOUT, errorcode = -8949 ikeVer
    Posted Dec 28, 2015 05:55 AM
    Client FW Routing issues - solved (not related to Aruba controller)
