RAP3 + 3G uplink (configuration not saved)
  • 1.  RAP3 + 3G uplink (configuration not saved)
    Posted Jul 17, 2013 02:52 AM
    I have a problem with a RAP3 and the uplink configuration. I use the RAP3 as an IAP and it seems that the uplink configuration is not saved. If I check the Current Configuration, I don't see anything about the 3G configuration and when I reboot my RAP, all the uplink configuration is gone.
    Any idea about that ? I do it thru the GUI and the firmware version is 6.2.1.0-3.3.0
    Dimitri
  • 2.  RE: RAP3 + 3G uplink (configuration not saved)
    Posted Jul 22, 2013 04:12 PM
    Have you tried upgrading to version 3.3.0.2?  Does this happen on more than one IAP?  Any chance you can post the config?
  • 3.  RE: RAP3 + 3G uplink (configuration not saved)
    Posted Jul 23, 2013 07:53 AM
    Finally it's ok with the last firmware.
  • 4.  RE: RAP3 + 3G uplink (configuration not saved)
    Posted Jul 23, 2013 08:49 AM
    Glad to hear it!
