RAP3 and 3G uplink problem
  • 1.  RAP3 and 3G uplink problem
    Posted Sep 26, 2013 03:37 AM
    I have a little issue with a RAP3 (used as an IAP) and 3G uplink. Here is the situation :
    - Configuration is ok for 3G uplink
    - 3G is working
    - IAP version is 6.2.1.0-3.4.0.1_39461
    But the only way to make 3G uplink up is to boot the RAP3 with eth0 connected to the network. In this case, 3G uplink is ok. If I boot the RAP3 only with the 3G key, the uplink never goes up.
    Any idea about this ?
    Dimitri
  • 2.  RE: RAP3 and 3G uplink problem
    Posted Sep 26, 2013 09:27 AM
    Problem solved. I have needed to enforce uplink for 3G/4G and now it's working as attended.
    Dimitri
  • 3.  RE: RAP3 and 3G uplink problem
    Posted Aug 15, 2014 08:51 AM
    EDIT , unneeded post of myself, found information here in forum.
