RAP3 conversion troubles
  • 1.  RAP3 conversion troubles
    Posted Aug 07, 2014 11:06 AM
    We recently got some RAP3s to test out. Out of the box they are IAPs and I managed to convert them to remote AP using the IP address of the controller, but it's not showing up in the AP list and the power LED on the RAP is blinking green.
    Did I miss something?
    Logs show no errors. Controller is an M3 running 6.3.1.3
  • 2.  RE: RAP3 conversion troubles
    Posted Aug 07, 2014 12:19 PM
    Have you added the RAPs to the whitelist?
  • 3.  RE: RAP3 conversion troubles
    Posted Aug 07, 2014 12:31 PM
    Do you see any traffic on the controller?
    Show datapath session table | include 4500
    Also, check the system logs for any errors
    Show log system 50
  • 4.  RE: RAP3 conversion troubles
    Posted Aug 07, 2014 12:51 PM
    - Make sure you have create RAP IP Pool so the RAP is able to get inner IP address
    - Also add the mac address in the RAP whitelist
  • 5.  RE: RAP3 conversion troubles
    Posted Aug 07, 2014 02:21 PM
    MAC addresses are in the whitelist and there is a RAP IP pool configured.
    I'm not sure how to interpret the information from show datapath session table.
    This is the output :
    rapIP controllerIP 17 49266 4500 0/0 0 0 0 0/1 0 1 418 FC
    controllerIP rapIP 17 4500 49266 0/0 0 0 0 0/1 1 2 533 F
  • 6.  RE: RAP3 conversion troubles
    Posted Aug 07, 2014 04:00 PM
    Have you looked at the logs on the controller for any info regarding why the RAP is not connecting? Based on your datapath output, it seems to be making the controller. Have you logged into the RAP itself (connect to the wired port and type "rapconsole.arubanetworks.com") to gather diagnostic info? Should have some logs you can gather that should point you in the right direction.
  • 7.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 09:34 AM
    As I connect to the RAPs E1 I'm not getting any IP address and rapconsole.arubanetworks.com isn't responding.
    Here is another fun bit of info
    #show crypto isakmp sa
    ISAKMP SA Active Session Information
    Initiator IP     Responder IP   Flags       Start Time            Private IP
    M3-2IP             M3-1-IP           r-a-p     Aug  8 05:50:46          -
    RAPlanIP        VRRP         r-v2-c-R  Aug  8 10:03:52     IPfromRAPpool
    According to this not only does it appear to be connecting but it is completing the tunnel correctly, so why can i not see it on the controller?
    Does the private IP need to be routable on our network?
  • 8.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 09:51 AM
    type "show datapath session table <ip address from rap pool>" a few times and see if the AP is communicating with the controller
  • 9.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 09:55 AM
    No there doesn't appear to be any communications to or from <RAP Private IP> in the session table.
  • 10.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 10:03 AM
    Type "show log system 50" and see if there is anything that the AP might have sent to the controller via syslog.
    Also, reboot the AP and try the "show datapath session table" after it connects and see if there anything is there.
  • 11.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 10:20 AM
    Thanks for helping,
    I've tried
    #show log all | include <name of rap>
    #show log all | include <private ip of rap>
    #show log all | include <local ip of rap>
    All returned no results.
    I've also tried rebooting the rap several times with same results.
    #show datapath session table | include 4500
    <rap lan ip>  <controller IP> 17   49154 4500   0/0     0 0   1   0/1         18   0         0          FC
     <controller IP> <rap lan ip>   17   4500  49154  0/0     0 0   1   0/1         19   0         0          FY
    The Y flag is troubling to me as the definition states that it mean "no syn"
    I'm not familiar with the connection process of a RAP so I couldn't begin to guess where the breakdown occurs.
  • 12.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 10:27 AM
    The RAP Lan IP is that routeable on your network? Can the controller get back to that IP if you do a traceroute?
  • 13.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 10:32 AM
    mnarine,
    Yes it is an IP provided by the local DHCP server and is on the same subnet as the controller.
    The controller is able to ping the address.
  • 14.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 10:37 AM
    Can you send the output of the following?
    show rights default-vpn-role
  • 15.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 10:41 AM
    #show rights default-vpn-role
    Unknown role default-vpn-role
  • 16.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 12:03 PM
    Yann,
    UDP traffic does not have a "SYN" so it will always say "no syn".  Don't worry about it.
    1. You should do "show datapath session table <outer ip address of ap>" - done
    2.  You should do "show crypto ipsec sa" - done
    3.  You should do "show datapath session table <inner ip address of rap>" <------This is what I am interested in.
    4.  Turn on security debugging:
    config t
    logging level debugging security subcat ike
    logging level debugging security process aaa
    logging level debugging security process authmgr
    logging level debugging security subcat l2tp
    logging level debugging security subcat vpn
    5.  Type "show log security 50" when the RAP is coming up to see if you see anything.
  • 17.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 01:32 PM
    "show datapath session table <inner ip address of rap>" Returns nothing.
    "show log security 50" Returns nothing specific to the RAP
  • 18.  RE: RAP3 conversion troubles
    Posted Aug 08, 2014 05:40 PM
    Please open a case.  I am out of guesses if those commands do not return any information.
  • 19.  RE: RAP3 conversion troubles
    Posted Aug 11, 2014 02:00 PM
    To anyone interested:
    I opened a case with support and what we discovered is that my default ap-role was blocking port 8209. Once this port was opened the RAPs came up in the AP list.
    Cheers.
