RAP3 with USB Modem K4605
  • 1.  RAP3 with USB Modem K4605
    Posted Jul 24, 2013 03:46 AM
    Hello, we have changed the USB modem connected on RAP3.
    Before we used K4505 and it worked without problems, now we use K4605 and we don’t have the device string and device ID for this modem.
    Someone can help me?
    Thanks and Best Regards
    Gian
  • 2.  RE: RAP3 with USB Modem K4605
    Posted Jul 28, 2013 09:34 PM
    Hi Gian
    Can you post the params you were using for the K4505? Huawei devices tend to all be using quite similar modeswitch etc., so let's start with the config that was working before.
    Looking online there are a couple of versions of K4506, so we do need to determine the "product ID" that yours is using. Please take the USB modem and put it in a windows pc, connect it to the internet using the USB modem then visit device manager -> ports (COM and LPT). You should see the Huawei (or perhaps named as Vodafone) modem listed under this section, right click on it and choose "properties" - a small box will open which has a tab called "details" - click this. Finally, in the dropdown box that now appears choose "hardware IDs" and copy out the string you see, it will look something like this:  USB\VID_12D1&PID_1003&REV_0000&MI_01
    regards
    -jeff
  • 3.  RE: RAP3 with USB Modem K4605
    Posted Jul 29, 2013 03:23 AM
    Thanks for your support!
    For K4505 USB modem I used the following params without problems:
    USB Device Identifier: 0x12d11464
    USB Dial String: ATDT*99***1#
    In attachment you can fnd the screnshoot required.
    Best Regards,
    Gian
  • 4.  RE: RAP3 with USB Modem K4605
    Posted Jul 29, 2013 07:18 AM
    HI Gian,
    for a first attempt, please set device ID to 0x12d114c6 and leave everything else the same. If that fails, we can try modeswitching it - but let's try easiest way first.
    regards
    -jeff
  • 5.  RE: RAP3 with USB Modem K4605
    Posted Jul 29, 2013 08:21 AM
    Thanks for your quickly reply. It was my first test :-) ... but without positive results.
    Thanks for your support.
    Gian
  • 6.  RE: RAP3 with USB Modem K4605
    Posted Jul 29, 2013 10:03 AM
    Gian
    ok, then let's try to modeswitch it. Please add the following, leaving the device id as in my last post and configure this in the USB modeswitch field, including the double quotes.
    "-v 0x12d1 -p 0x14c1 -M 55534243123456780000000000000011062000000100000000000000000000"
    regards
    -jeff
  • 7.  RE: RAP3 with USB Modem K4605
    Posted Jul 29, 2013 11:49 AM
    Thanks for your quichky reply!
    I have added the USB modeswitch as you suggest, but the Controller requires backslash before double quotes, so I have added it in this format:
    \"-v 0x12d1 -p 0x14c1 -M 55534243123456780000000000000011062000000100000000000000000000\"
    Nothing to do... it doesn't work!
    Gian
  • 8.  RE: RAP3 with USB Modem K4605
    Posted Jul 29, 2013 12:17 PM
    controller CLI shouldnt need backslash, webui may want single quote, can you try both?
  • 9.  RE: RAP3 with USB Modem K4605
    Posted Jul 29, 2013 12:44 PM
    Only one info: in the old configuration (where K4505 works) I configured:
    no USB modeswitch
    Now we have changed the USB Device Identifier to : 0x12d114c6 and added the USB modeswitch as you suggested.
    In this new config USB Dial String field will be the same or I have to delete it?
    Best Regards
    Gian
  • 10.  RE: RAP3 with USB Modem K4605
    Posted Jul 29, 2013 08:57 PM
    Hi Gian
    yes, dialstring should remain the same - the changes are the device ID and adding the modeswitch string.
    regards
    -jeff
  • 11.  RE: RAP3 with USB Modem K4605
    Posted Jul 30, 2013 04:25 AM
    Great! It works:
    I have inserted the modeswitch via CLI it works!
    Provisioning profile "K4605"
    Parameter Value
    Remote-AP Yes
    Master IP/FQDN 195.64.188.62
    PPPOE User Name N/A
    PPPOE Password N/A
    PPPOE Service Name N/A
    USB User Name N/A
    USB Password N/A
    USB Device Type option
    USB Device Identifier 0x12d114c6
    USB Dial String ATDT*99#
    USB Initialization String N/A
    USB TTY device data path N/A
    USB TTY device control path N/A
    USB modeswitch parameters -v 0x12d1 -p 0x14c1 -M 55534243123456780000000000000011062000000100000000000000000000
    Link Priority Ethernet 10
    Link Priority Cellular 5
    Cellular modem network preference auto
    Username of AP so that AP can authenticate to 802.1x using PEAP N/A
    Password of AP so that AP can authenticate to 802.1x using PEAP N/A
    Uplink VLAN 0
    USB power mode auto
    Jul 30 10:09:02  isakmpd[1591]: <103076> <INFO> |ike|  IKEv2 IPSEC Tunnel created for peer 109.114.57.244:49157
    Jul 30 10:09:02  isakmpd[1591]: <103077> <INFO> |ike|  IKEv2 IKE_SA succeeded for peer 109.114.57.244:49157
    Jul 30 10:09:02  isakmpd[1591]: <103078> <INFO> |ike|  IKEv2 CHILD_SA successful for peer 109.114.57.244:49157
    Jul 30 10:09:02  isakmpd[1591]: <103082> <INFO> |ike|  IKEv2 Client-Authentication succeeded for 172.20.1.45
    Now... If I have other USB Modem what is the easiest way to find  the correct params?
    Best Regards
  • 12.  RE: RAP3 with USB Modem K4605
    Posted Jul 30, 2013 04:45 AM
    Hi Gian
    Glad to hear it's working. The way I would usually find the parameters is to go to Google and search for hits on the usb_modeswitch website - in this case, this link turned up http://www.draisberghof.de/usb_modeswitch/bb/viewtopic.php?t=672
    On that page we can see a discussion about the K4605 modem and what people had to do to get it to work. Sometimes you will see people post output like this:
    # cat /etc/usb_modeswitch.d/12d1:14c1
    # Vodafone (Huawei) K4605
    TargetVendor= 0x12d1 TargetProduct= 0x14c6 MessageContent="55534243123456780000000000000011062000000100000000000000000000"
    in which case the deviceID to be added to the Aruba provisioning will be 0x12d114c6 and the modeswitch will need that string indicated as MessageContent. Two other items are needed to complete the modeswitch string, and that is the deviceID before it switches - that can be determined from the name of the file, in this case 12d1:14c1.
    Hence, we can now form the modeswitch to be "-v 0x12d1  -p 0x14c1  -M555342431234567<snip>"
    regards
    -jeff
    to recap for clarity in the solution, for a Huawei/Vodaphone K4605:
    USB modeswitch       -v 0x12d1 -p 0x14c1 -M 55534243123456780000000000000011062000000100000000000000000000
    * Note that Huawei modems dont generally need a ttyUSB to be specified (defaults to ttyUSB0 which is what Huawei uses) and that Modeswitch should be entered from CLI with double quotes around the whole line.
  • 13.  RE: RAP3 with USB Modem K4605
    Posted Jul 30, 2013 04:53 AM
  • 14.  RE: RAP3 with USB Modem K4605
    Posted Oct 10, 2013 05:25 AM
    Can you help me about HUAWEI E3131?
    Gian
