RAP5 connectivity issues
  • 1.  RAP5 connectivity issues
    Posted Apr 08, 2013 05:56 PM
    Hello all!
    I have a rap5 at a remote office and they are complaining about getting dropped and low signal strength. The unfortunately part of the equation is that they are in a shared space and the aps that are there seem to be massively interfering with the AP.
    here's what I see  on the details of the AP:
    Default
    Radio Mode Access
    Clients 3
    Channel 1
    Noise Floor (dBm) -86
    EIRP (dBm) 21
    Channel Utilization       23%TX, 27% RX 4% interference
    Goodput (bps) 1.8 M
    Usage (bps) 206.6 K
    Frames 7.5 K
    Frames (to client) 6.1 K
    Frames Retried (to client) 6% (376/6.1 K)
    Frames Dropped (to client) 0%
    Frames (from client) 1.4 K
    Frames Retried (from client) 18% (261/1.4 K)
    Air Quality
    Channel 1
    Channel Utilization     22%tx/25%rx/4%interference
    Channel Busy 56%
    Channel Free 44%
    Air Time (from ap) 24%
    Air Time (to AP) 29%
    Rx Data Frames (heard from other radios) 34% (729/2.2 K)
    Interference 3%
    Tx/Rx Stats
    Clients 3
    Goodput (bps) 1.8 M
    Usage (bps) 206.6 K
    Bytes 1.5 M
    Frames 7.5 K
    Frame Rates (to client)       2%-36-54, 10% 54-108 and 11% 108+
    Goodput (bps) (to client) 1.2 M
    Frame Rates (from client)         6-12 - 1%, 12-24 2%, 24-36  3%, 36-54 22%, 54-108 5%, 108+ 66%
    Goodput (bps) (from client) 20.0 M
    Clients
    SNR (dB) 0,0,0,1,1,0,1,0,0,0
     AP is currently located near the ceiling right now - not sure how they have it sitting - I'm trying to get them to move it to a desk to see if that helps. - Not really pleased with the -86 Noise Floor - not sure if there is anything I can do to improve that.
    Any suggestions would be appreciated.
    Thank you
    lirria
  • 2.  RE: RAP5 connectivity issues
    Posted Apr 08, 2013 08:49 PM
    Why not set the RAP 5 to use the 5 ghz radio instead of the 2.4?
  • 3.  RE: RAP5 connectivity issues
    Posted Apr 09, 2013 09:52 AM
    We needed to set it to 2.4 because of other network issues - unfortunately if it's set to 5ghz even if the network priority is set to wired, the wireless is still faster so the computer prefers that - which then causes issues eventually with AD authentication and the the backups we do just don't work - I can't figure out why - over wireless.
    Lirria
  • 4.  RE: RAP5 connectivity issues
    Posted Apr 11, 2013 06:49 PM
    Your interference could be caused by something in the ceiling, so move it away from that.  In addition the RAP5 is not plenum rated, so you might want to sit it on a desk...
  • 5.  RE: RAP5 connectivity issues
    Posted Apr 11, 2013 08:12 PM
    Yes, that is the next step, trying to work with the on site people to get it moved to a desk to see if that helps, hopefully in the next day or so I should be able to do that.
    Lirria
