RAP5 Upgrade Without Internet
  • 1.  RAP5 Upgrade Without Internet
    MVP
    Posted Aug 06, 2013 09:37 AM
    I have two RAP-5WN devices that I need to have updated to current version. Only problem I'm having is that I do not have a controller's address to give the RAP at the moment. Is there any way to upgrade it without entering an address. I don't need the SSIDs to broadcast, just upgrade the version.
    Thanks for the help!
  • 2.  RE: RAP5 Upgrade Without Internet
    Posted Aug 06, 2013 09:41 AM
    You can call TAC or if you have a controller locally, you can plug them in on the internal network.
  • 3.  RE: RAP5 Upgrade Without Internet
    MVP
    Posted Aug 06, 2013 09:44 AM
    Thanks for the input. My problem is that the master controller is at another site and it's not on the same network as I'm currently on. I'm waiting for a response with the master's hostname or IP, but I was hoping to get it upgraded while I waited.
    Thanks! If I don't hear back I may contact TAC to see if theres any type of work around.
  • 4.  RE: RAP5 Upgrade Without Internet
    Posted Aug 06, 2013 09:47 AM
    Can you resolve aruba-master.yourdomain.com?
    If so?try that address...
  • 5.  RE: RAP5 Upgrade Without Internet
    MVP
    Posted Aug 06, 2013 04:48 PM
    Update:
    After obtaining the IP of the controller, ran into problem that RAP hasn't been whitelisted. Will do a remote session to whitelist RAPs and upgrade images. Problem should be solved.
