RAP5 with PPPoE, possible MTU issue
  • 1.  RAP5 with PPPoE, possible MTU issue
    Posted Mar 19, 2013 05:54 AM
    Hello all,
    I'm having a RAP5 AP connected to a DSL modem using PPPoE for dialing to the internet. The profile is configured to use split tunnel: traffic for corporate LAN is going though the tunnel, internet traffic is going out locally.
    Now for the issue: Some internet sites (tested with www.microsoft.com) cannot be opened in the browser, while others can. I have it down for a possible MTU problem, for when I reduce the max.TCP segement size on the client it works. When I use a DSL router in front of the RAP5 everything works fine, when using a DSL modem and PPPoE the issues occur.
    I wonder if there is a way to tell the RAP5 to use a reduced MTU when connecting?
    I have tried to change the SAP MTU value in the AP System Profile (lowest value 1200) but this does have no effect.
    Thanks in advance, cheers!
