RAPNG - did I miss something
  • 1.  RAPNG - did I miss something
    Posted Mar 05, 2017 02:55 PM
    Hi guys. Still working in my labs. Been through the IAP-VPN section of the guide .... but after setting up i see that the RAP takes one IP from local pool, disconnects - reconnects with a new IP - disconnects... etc.
    Mar 5 20:51:34 fpapps[5184]: <399838> <5189> <WARN> |fpapps| Received TUN_DOWN from IKE for 12.12.12.1-192.168.110.104
    Mar 5 20:51:34 fpapps[5184]: <399838> <5189> <WARN> |fpapps| Received TUN_UP from IKE for 12.12.12.1-192.168.110.105 mapid 0, vlanid 0, flags = 0x0 uplink_priority 0
    Mar 5 20:51:34 fpapps[5184]: <399841> <5189> <ERRS> |fpapps| |configuration| Configuration error: Unable to find the ipsec map for tunnel down event. ip 192.168.110.104 in procIkeIpsecMsg, arubaIpsecRouteUtils.c:421.
  • 2.  RE: RAPNG - did I miss something
    Posted Mar 05, 2017 11:16 PM
    Hi Jakob,
    Is there a firewall in between IAP/Controller which could be blocking IPSEC traffic?
    Is the IAP already whitelisted/ part of trusted branch-db on Controller?
  • 3.  RE: RAPNG - did I miss something
    Posted Mar 06, 2017 02:17 AM
    Hi
    thanks for getting back to me.
    The firewall is opened for UDP4500 and port forwarded to internal IP for controller, and IAP is behind a any-any firewall.
    Should probably mention:
    - Controller is VMC standalone 8.0.1
    - IAP is 6.5.1.0-4.3.1.1_57902 - and controlled by Central.
    I find very little configuration possibilities in regards to VPN on Central; no NAT Traversal.
    also - the guide mentions nothing in regards to routing for VPN traffic - but that should be handled by OSPF setup?
