I solved the issue - upgarde 7205 to software 8.6.0 and default IDS profile comes up. RAP connect properly and working fine
(7205-WARSC006) [MDC] *#show ap database
AP Database
Name Group AP Type IP Address Status Flags Switch IP Standby IP
9c:1c:12:c9:5e:95 default 105 10.1.1.2 Up 3m:10s Rc2 213.241.33.26 0.0.0.0
Flags: 1 = 802.1x authenticated AP use EAP-PEAP; 1+ = 802.1x use EST; 1- = 802.1x use factory cert; 2 = Using IKE version 2
B = Built-in AP; C = Cellular RAP; D = Dirty or no config
E = Regulatory Domain Mismatch; F = AP failed 802.1x authentication
G = No such group; I = Inactive; J = USB cert at AP; L = Unlicensed
M = Mesh node
N = Duplicate name; P = PPPoe AP; R = Remote AP; R- = Remote AP requires Auth;
S = Standby-mode AP; U = Unprovisioned; X = Maintenance Mode
Y = Mesh Recovery
c = CERT-based RAP; e = Custom EST cert; f = No Spectrum FFT support
i = Indoor; o = Outdoor; s = LACP striping; u = Custom-Cert RAP; z = Datazone AP
p = In deep-sleep status
4 = WiFi Uplink
r = Power Restricted; T = Thermal ShutDown
Thank YOU
