RAPS flapping after migration 6.5.x -> 8.5.x
  • 1.  RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 19, 2020 10:18 AM
    I'm expecting strange issue with RAPs fllaping - below log:
    Mar 19 06:02:07 stm[3735]: <305027> <3735> <ERRS> |stm| AP 9c:1c:12:c9:5e:95: No valid instances of required profile "ids signature-matching-profile"
    Mar 19 06:02:15 stm[3735]: <305004> <3735> <ERRS> |stm| AP 9c:1c:12:c9:5e:95: ids signature-matching-profile "default" is invalid.
    Mar 19 06:02:15 stm[3735]: <305027> <3735> <ERRS> |stm| AP 9c:1c:12:c9:5e:95: No valid instances of required profile "ids signature-matching-profile"
    Mar 19 06:02:23 AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    9c:1c:12:c9:5e:95 default 105 10.1.1.233 Up 12m:49s Rc2ID 213.241.33.26 0.0.0.0
    Flags: 1 = 802.1x authenticated AP use EAP-PEAP; 1+ = 802.1x use EST; 1- = 802.1x use factory cert; 2 = Using IKE version 2
    B = Built-in AP; C = Cellular RAP; D = Dirty or no config
    E = Regulatory Domain Mismatch; F = AP failed 802.1x authentication
    G = No such group; I = Inactive; J = USB cert at AP; L = Unlicensed
    M = Mesh node
    N = Duplicate name; P = PPPoe AP; R = Remote AP; R- = Remote AP requires Auth;
    S = Standby-mode AP; U = Unprovisioned; X = Maintenance Mode
    Y = Mesh Recovery
    c = CERT-based RAP; e = Custom EST cert; f = No Spectrum FFT support
    i = Indoor; o = Outdoor; s = LACP striping; u = Custom-Cert RAP; z = Datazone AP
    p = In deep-sleep status
    4 = WiFi Uplink
    Mar 19 06:02:23 stm[3735]: <305027> <3735> <ERRS> |stm| AP 9c:1c:12:c9:5e:95: No valid instances of required profile "ids signature-matching-profile"
    M
    I was using mig tool to mirate I did not change any default IDS, roles, policy etc...
    There is ID flag - sth wrong ?
    Does anybody have the same issue?
  • 2.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    MVP EXPERT
    Posted Mar 19, 2020 10:21 AM
    The 'D' flag means that there is either dirty or no config. Have you reviewed your configuration for errors with 'show profile-errors'.
    Do you have any more information about your environment, such as a cluster, MM's involved, have you added the NAT IPs etc?
  • 3.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 19, 2020 10:26 AM
    (7205-WARSC006) [MDC] *#show profile-errors Invalid Profiles ---------------- Profile Error ------- ----- ids signature-matching-profile "default" IDS Signature Profile "Deauth-Broadcast" does not exist
    No RAP Cluster just single 7205+VMM (soft 8.5.0)
    I did not touched any IDS profile after migration....
  • 4.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    MVP EXPERT
    Posted Mar 19, 2020 10:30 AM
    Do you have an RFP License? If so have you enabled it and the feature bit after the migration? It is advising that the IDS Signature Profile "Deauth-Broadcast" does not exist. If the RFP License isn't causing the issue, set the IDS Signature Profile to 'default' as a test and see if the RAP comes up. You then may need to re-create the IDS Signature Profile "Deauth-Broadcast".
    IDS Profile "default"
    Parameter                        Value
    IDS General profile              default
    IDS Signature Matching profile   default
    IDS DOS profile                  default
    IDS Impersonation profile        default
    IDS Unauthorized Device profile  default
  • 5.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 19, 2020 12:02 PM
    Building Configuration...
    ids management-profile
    ids wms-general-profile
    ids wms-local-system-profile
    ids ap-rule-matching
    ids general-profile "default"
    ids rate-thresholds-profile "default"
    ids rate-thresholds-profile "probe-request-response-thresholds"
    ids signature-profile "AirJack"
    ids signature-profile "ASLEAP"
    ids signature-profile "Deauth-Broadcast-From-Valid-AP"
    ids signature-profile "default"
    ids signature-profile "Disassoc-Broadcast"
    ids signature-profile "Disassoc-Broadcast-From-Valid-AP"
    ids signature-profile "Netstumbler Generic"
    ids signature-profile "Netstumbler Version 3.3.0x"
    ids signature-profile "Null-Probe-Response"
    ids signature-profile "Wellenreiter"
    ids impersonation-profile "default"
    ids unauthorized-device-profile "default"
    ids dos-profile "default"
    ids profile "default"
    wids-event-info-enable
    logging security subcat ids level warnings
    logging security subcat ids-ap level warnings
    Nothing changes
    Licensing:
    License Summary
    License Description Status Expiration Total Installed
    AP Access Points Partially Expiring - Expires in 22 days 2020-04-10 09:26:13 2052
    PEFNG Policy Enforcement Firewall Partially Expiring - Expires in 22 days 2020-04-10 09:26:26 2052
    RFP RF Protect(WIP,Spectrum,Multi-zone) Not Licensed Not Licensed 0
    ACR Advanced Cryptography Not Licensed Not Licensed 0
    WebCC Web Content Classification Not Licensed Not Licensed 0
    MM Mobility Master Virtual Appliance Active Never 100
    MC-VA-RW Controller Virtual Appliance(RW) Not Licensed Not Licensed 0
    MC-VA-EG Controller Virtual Appliance(EG) Not Licensed Not Licensed 0
    MC-VA-IL Controller Virtual Appliance(IL) Not Licensed Not Licensed 0
    MC-VA-JP Controller Virtual Appliance(JP) Not Licensed Not Licensed 0
    MC-VA-US Controller Virtual Appliance(US) Not Licensed Not Licensed 0
    VIA VIA VPN Client(Session-based) Not Licensed Not Licensed 0
    RPF is not active but in the logs I do not see that there is problem with platform limits
  • 6.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 19, 2020 10:42 AM
    Do you have an LMS-IP to a private ip address in the AP system profile of that ap-group?  If yes, create a new ap-group with a new AP system profile that does not have anything in the lms-ip.
  • 7.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 19, 2020 12:12 PM
    I do not have LMS IP config in my AP System Profile:
    (7205-WARSC006) [MDC] *# show ap system-profile New_APsystem
    AP system profile "New_APsystem"
    Parameter Value
    RF Band g
    Recovery Mode auto
    RF Band for AM mode scanning all
    Native VLAN ID 1
    WIDS AMPDU Optimization Enabled
    Tunnel Heartbeat Interval 1
    Session ACL ap-uplink-acl
    Corporate DNS Domain N/A
    SNMP sysContact N/A
    LED operating mode (11n/11ac APs only) normal
    LED override Disabled
    Driver log level warnings
    Console log level emergencies
    SAP MTU N/A
    RAP MTU 1100 bytes
    LMS IP N/A
    Backup LMS IP N/A
    LMS IPv6 N/A
    Backup LMS IPv6 N/A
    LMS Preemption Disabled
    LMS Hold-down Period 600 sec
    LMS ping interval 20
    Remote-AP DHCP Server VLAN N/A
    Remote-AP DHCP Server Id 192.168.11.1
    Remote-AP DHCP Default Router 192.168.11.1
    Remote-AP DHCP DNS Server N/A
    Remote-AP CORP DNS Server N/A
    Remote-AP CORP DNS Server IPV6 N/A
    Remote-AP DHCP Pool Start 192.168.11.2
    Remote-AP DHCP Pool End 192.168.11.254
    Remote-AP DHCP Pool Netmask 255.255.255.0
    Remote-AP DHCP Lease Time 0 days
    Remote-AP uplink total bandwidth 0 kbps
    Remote-AP bw reservation 1 N/A
    Remote-AP bw reservation 2 N/A
    Remote-AP bw reservation 3 N/A
    Remote-AP Local Network Access Disabled
    Flex Radio Mode 2.4GHz-and-5GHz
    Dual 5GHz Mode Automatic
    IPM activation Disabled
    IPM power reduction steps with priorities disable_usb/priority:1
    IPM power reduction steps with priorities disable_alt_eth/priority:2
    IPM power reduction steps with priorities disable_pse/priority:3
    IPM power reduction steps with priorities radio_2ghz_power_3dB/priority:4
    IPM power reduction steps with priorities radio_5ghz_power_3dB/priority:5
    IPM power reduction steps with priorities cpu_throttle_75/priority:6
    IPM power reduction steps with priorities radio_2ghz_power_6dB/priority:7
    IPM power reduction steps with priorities radio_5ghz_power_6dB/priority:8
    IPM power reduction steps with priorities radio_2ghz_chain_3x3/priority:9
    IPM power reduction steps with priorities radio_5ghz_chain_3x3/priority:10
    IPM power reduction steps with priorities radio_2ghz_chain_2x2/priority:11
    IPM power reduction steps with priorities radio_5ghz_chain_2x2/priority:12
    IPM power reduction steps with priorities radio_2ghz_chain_1x1/priority:13
    IPM power reduction steps with priorities radio_5ghz_chain_1x1/priority:14
    IPM power reduction steps with priorities cpu_throttle_50/priority:15
    IPM power reduction steps with priorities cpu_throttle_25/priority:16
    IPM Steps delete all No
    Bootstrap threshold 8
    Double Encrypt Disabled
    Heartbeat DSCP 0
    Management DSCP N/A
    IP DSCP to VLAN 802.1p priority mapping N/A
    Maintenance Mode Disabled
    Maximum Request Retries 10
    Request Retry Interval 10 sec
    Number of IPSEC retries 85
    Secondary Master IP/FQDN N/A
    AeroScout RTLS Server N/A
    RTLS Server configuration 35.241.143.144:60000:********:2:enable
    RTLS Server Compatibility Mode Enabled
    SES-imagotag ESL Server IP N/A
    SES-imagotag ESL Channel N/A
    SES-imagotag ESL Radio Coexistence Enabled
    Slow Timer Recovery by rebooting itself Enabled
    Telnet Disabled
    Disable RAP Tftp Image Upgrade Disabled
    Image URL N/A
    Spanning Tree Disabled
    AP multicast aggregation Disabled
    AP ARP attack protection Disabled
    AP multicast aggregation allowed VLANs none
    Console enable Enabled
    AP Console Protection Enabled
    AP Console Password ********
    Password for Backup ********
    AP USB Power mode auto
    AP POE mode shared
    RF Band for Backup all
    Operation for Backup off
    BLE Operation Mode Disabled
    GRE offload Enabled
    Bridge offload Enabled
    Health Check Disabled
    Health Check Parameter mode ping packet-size 32 burst-size 5 report 60 frequency 10 retries 3
    AirMatch Report Period 30 minutes
    AirMatch Measurement Duration 5 minutes
    AirMatch Report Enabled Enabled
    AP Deploy-hour N/A
    Dump collection profile default
  • 8.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    MVP EXPERT
    Posted Mar 19, 2020 12:14 PM
    Was all of the VLANs correctly migrated over and are they all present in your VAP profiles? This can be a reason why the I flag is set, what about the regulatory domains as well. Is the AP in question matching the regulatory domain of the controller?
  • 9.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 19, 2020 02:15 PM
    All VAP Profiles seems to be migrated corectly, AP group configuration, roles, policies, RAP whitelist etc...
    I alreday open TAC case for this issue.
    Thanks for Your time
  • 10.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 19, 2020 02:47 PM
    Are you terminating the RAP on a cluster?
  • 11.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 19, 2020 03:27 PM
    There is no cluster - only 7205 + VMM
  • 12.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 30, 2020 05:51 AM
    There was a problem with default IDS profile after migration using mig_tool. Problem was solved upgrading controler to newes version od software 8.6.0.2 and all RAPs are working fine.
  • 13.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 30, 2020 06:03 AM
    I honestly still don't know what the IDS profile has to do with Remote APs flapping, but if that fixed it for you, good.
  • 14.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 31, 2020 05:58 AM
    I dont think it is related.
    We had the same issue, it was a bug in AOS8 that caused a IP-conflict between the RAPs. It should be easy to spot in cli.
  • 15.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 31, 2020 06:01 AM
    If you know for sure, please circle back and tell us what that is, because it doesn't sound familiar.
  • 16.  RE: RAPS flapping after migration 6.5.x -> 8.5.x
    Posted Mar 19, 2020 12:40 PM
    To be honest, there could be a bazillion things wrong after a migration.  You might want to open a TAC case to get to the bottom of the RAP portion of it.  We are just guessing here.
