RAP's only up for 15 secs ??
  • 1.  RAP's only up for 15 secs ??
    Posted Aug 10, 2015 07:50 AM
    Hi all, after a ton of grief getting a juniper fwall to allow RAP's in, I have finally seen 2 test RAPs on the controller come up, get an inner IP.  They then drop after about 15 secs ?? I have them configured using PSK, not certs, any suggestion to troubleshoot this ??
  • 2.  RE: RAP's only up for 15 secs ??
    Posted Aug 10, 2015 07:54 AM
    #1 reason:
    Do you have a private ip address for the LMS-IP in the AP system profile?  If you do, remove it.
    By the way, nobody uses a PSK for raps, because it is less secure and harder to use than simple certificate-based.
  • 3.  RE: RAP's only up for 15 secs ??
    Posted Aug 10, 2015 08:06 AM
    Colin,many thanks, never come across that before and dont recall it in any docs, yes thats done the trick, will now reprovision with certs..
