Aruba Central
Re-add deleted offline device
  • 1.  Re-add deleted offline device
    Posted Nov 09, 2022 04:20 PM
    I've an offline switch 2930M in Aruba Central that is actually not offline. I've tried to fix it be removing/delete the offline device.  It is still in the inventory though.
    I assume that the device should appear automatically on it own in Aruba Central, right?  If things are going well...
    Unfortunately that's not the case. I can't find the device with the SN or MAC in Aruba Central.
    Is there a way trigger the switch to contact Aruba Central?
    Should I remove the switch from the inventory altogether and re-add it?
    Is there a way to test connectivity from the switch to Aruba Central?
    Thanks in advance for your hints.
  • 2.  RE: Re-add deleted offline device
    MVP GURU
    Posted Nov 09, 2022 07:27 PM
    You can issue the "show arubacentral" and "show activate provision" commands to check the status. I believe jumping into config t and then issuing the "aruba-central disable" and "aruba-central enable" commands. write mem to toggle between.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Re-add deleted offline device
    MVP GURU
    Posted Nov 09, 2022 07:28 PM
    Have you also added the switch to your inventory in central? Applies Subscription?
    Dustin Burns
  • 4.  RE: Re-add deleted offline device
    Posted Jan 26, 2023 06:09 AM
    It has been a while, sorry for the delayed response.
    Aruba-Central disable and enable has helped with one of the switches, but with all others it didn't help.  I've found a few more hint's here but nothing has helped in my case. It has turned out that there was an issue with the Aruba-Central backend - something with duplicated folders. After that was fixed by HPE support, switches could be added to Central.
    I'm still having the same issues with a few more switches (fail-prov-no-rule error message), but I'll try to sort it out with HPE support.
    Device Subscriptions are there, but it' still not coming into Central.
    Thanks for your help
