re-authentication automaticlly
  • 1.  re-authentication automaticlly
    Posted Apr 28, 2015 10:33 AM
    I have big problem with CPPM. It's re-authenticate every 8 mini however I have closed this feature from all switches at the company and made the session time out for all profiles equal 12 hours but this issue still there. but I cannot find which parameter could make me able to control the re-authentication proccess
  • 2.  RE: re-authentication automaticlly
    Posted Apr 28, 2015 10:37 AM
    Re-authentication is generally triggered by the NAD. Is this a switch or
    wireless controller?
  • 3.  RE: re-authentication automaticlly
    Posted Apr 28, 2015 10:44 AM
    AOS ignores a session timeout sent back via RADIUS if it already has one configured in the AOS settings.
    So, if you are using AOS, remove those session timeouts first.
  • 4.  RE: re-authentication automaticlly
    Posted Apr 28, 2015 11:02 AM
    It's Avaya Switches. but I have closed the re-authentication from all switches.
    is this request sent by CPPM or switches??
    if I want to have control on time that sending re-authentication requests which parameter on CPPM maybe have related for all of these requests???
  • 5.  RE: re-authentication automaticlly
    Posted Apr 28, 2015 11:04 AM
    If you are not sending anything from ClearPass then there is a setting on the switch that is causing the reauth. It could be a global reauthentication timer or an 802.1X timer.
