Re-Authentication Configuration
  • 1.  Re-Authentication Configuration
    Posted Mar 20, 2017 03:19 AM
    We are trying to configure the length of use of the internet. The enduser requires us to limit the tenant to access the internet for only one hour and after that they need to re-authenticate in the captive portal to gain access again.
    We are currently using a 7205 mobility controller and AP315 in the deployment.
    BR,
    Carlo
  • 2.  RE: Re-Authentication Configuration
    Posted Mar 20, 2017 05:02 AM
    In your guest user role you can configure a reauthentication interval.Set this to 60 minutes.
    Re-authentication Interval (optional)
    Time, in minutes, after which the client is required to reauthenticate. Enter a value between 0-4096. 0 disables reauthentication.
    Default: 0 (disabled)
    http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Content/ArubaFrameStyles/Firewall_Roles/User_Roles.htm
