Re: Captive Portal Aruba Controller 7030
  • 1.  Re: Captive Portal Aruba Controller 7030
    Posted Dec 19, 2019 02:41 AM
    This was solved through TAC after 2 days.
    It seems that there is an issue with enabling Captive Portal when no PEF-ENG licence is available.
    TAC created all the settings required from sctratch one by one(roles,virtual ap ,ssid,essid, acls, etc..).
    Infact when i try to view settings from the GUI most of them are blanks, which have to rollback if touched. The SSID is not setup as guest but as employee type. Furthermore, without PEF-ENG there ca only be one Captive Portal Policy / SSID.
    Everytime you enable PEF-ENG and disable PEF-ENG a restart of the controllers is required as settings will not work properly.
    below find the configuration provided implemented by TAC
    ip access-list session logon-control
     user any udp 68 deny
     any any svc-icmp permit
     any any svc-dns permit
     any any svc-dhcp permit
     any any svc-natt permit
     any network 169.254.0.0 255.255.0.0 any deny
     any network 240.0.0.0 240.0.0.0 any deny
    ip access-list session captiveportal
     user alias controller svc-https dst-nat 8081
     user any svc-http dst-nat 8080
     user any svc-https dst-nat 8081
     user any svc-http-proxy1 dst-nat 8088
     user any svc-http-proxy2 dst-nat 8088
     user any svc-http-proxy3 dst-nat 8088
    ip access-list session captiveportal6
      ipv6  user   alias controller6 svc-https  captive
      ipv6  user any svc-http  captive
      ipv6  user any svc-https  captive
      ipv6  user any svc-http-proxy1  captive
      ipv6  user any svc-http-proxy2  captive
      ipv6  user any svc-http-proxy3  captive
    ip access-list session v6-logon-control
     ipv6 user any udp 546 deny
     ipv6 any any svc-v6-icmp permit
     ipv6 any any svc-v6-dhcp permit
     ipv6 any any svc-dns permit
     ipv6 any network fc00::/7 any permit
     ipv6 any network fe80::/64 any permit
     ipv6 any alias ipv6-reserved-range any deny
    aaa profile "Wifi_Guest"
        initial-role "Wifi_Guest"
        dot1x-server-group "internal"
    aaa authentication captive-portal "Wifi_Guest"
        default-role "Wifi_Guest"
        show-acceptable-use-policy
    wlan virtual-ap "Wifi_Guest"
        aaa-profile "Wifi_Guest"
        vlan 255
        ssid-profile "Wifi_Guest"
    user-role aruba1234-guest-logon
        captive-portal Wifi_Guest
    ap-group "default"
    wlan ssid-profile "wifi_Guest"
        essid "Wifi_Guest"
