After my disastrous attempt at using the 6.5 upgrade tool yesterday, I'm trying to manually upgrade/get things back up and running. On my cluster master it shows that all my subscriber nodes have a status of disabled. I've brought 1 of my subscribers back up but the cluster master still says the node is disabled.
How to I enable it again?
A
CLI is a wonderful thing.
cleared cluser database and re joined and it worked.,,,,
Now have a 6.5 cluster upgraded from 6.4 ... should never have used the upgrade tool and stuck to cli
..now to apply 6.5 patch 1 and the leap second patches ....
