last person joined: 4 hours ago
Re-entering License Key Problem
  • 1.  Re-entering License Key Problem
    Posted Aug 27, 2013 04:17 PM
    Well, I did a "write erase all" and the license got wiped.
    I am now re-entering the license but I am getting:
    "License key for feature Policy Enforcement Firewall Module is not supported for ArubaOS"
    I searched and there seem to be no problem with solution like this. What seem to be the problem?
    I attached screenshots. Thank you.
  • 2.  RE: Re-entering License Key Problem
    Posted Aug 27, 2013 04:32 PM
    What version of ArubaOS is the controller on right now?     It looks like that might be for an old PEF license, not a PEF-NG (post 5.x).   If you log into the licensing portal; http://licensing.arubanetworks.com you should see a pre 5.x and post 5.x license for PEF/PEF-NG.
  • 3.  RE: Re-entering License Key Problem
    Posted Aug 27, 2013 04:47 PM
    I think it is ver 6.1.x.x
    Please see attached screenshot.
    Does that mean I need to get a new post 5.x lic?
    Thank you.
    *******EDIT*********
    SOLVED.
    I login here  http://licensing.arubanetworks.com and got the post 5.0 license key.
    Thank you.
