Re: How to delete an AP from the Controller
This thread has been viewed 22 times
  • 1.  Re: How to delete an AP from the Controller
    Posted Mar 02, 2020 10:27 AM
    Just a quick update
    ap-move didnt work in my scenario
    But i've managed to make it work by making the AP controller less in the MM using
    ap redeploy controller-less wired-mac <mac-address>
    or if it's more than one AP in the same group
    ap redeploy controller-less ap-group <group-name>
  • 2.  RE: Re: How to delete an AP from the Controller
    Posted Mar 02, 2020 10:52 AM
    What scenario is that?  Are the clusters on different versions of ArubaOS code?
  • 3.  RE: Re: How to delete an AP from the Controller
    Posted Mar 02, 2020 11:54 AM
    No - there are 8 clusters and all of them on the same version
  • 4.  RE: Re: How to delete an AP from the Controller
    Posted Mar 02, 2020 11:56 AM
    You mentioned Ap-move would not work in your scenario.  What scenario is that?
  • 5.  RE: Re: How to delete an AP from the Controller
    Posted Mar 02, 2020 12:55 PM
    Thats the error i received when i tried the ap-move command on the MM
  • 6.  RE: Re: How to delete an AP from the Controller
    Posted Mar 02, 2020 01:00 PM
    I don't see an error.
    EDIT: You didn't attach an error message to your post.
  • 7.  RE: Re: How to delete an AP from the Controller
    Posted Mar 11, 2020 01:05 PM
    I use apmove command from the MD the AP is active on works great. I was able to move AP's from one cluster to another the AP radio was only down for about 5-7 seconds. You said did it from the MM you have to run the CLI command directly on the controller the AP is active on.
    I had to move about 50 AP's from one cluster to another I created a spread sheet of commands pasted them in batch at a time. It was much faster then re-provisioning.
  • 8.  RE: Re: How to delete an AP from the Controller
    Posted Mar 11, 2020 01:36 PM
    You can move entire ap-groups of ap's.  You don't have to do it individually.
  • 9.  RE: Re: How to delete an AP from the Controller
    Posted Mar 11, 2020 02:11 PM
    Yes- Actualy that what i ended up doing. Set the IP address from DHCP to static and Put the IP address of the new controller. The APs alligned themselives to the new controller, once they came back after the reboot, changed the AP Group and changed the IP back to DHCP.
