Network Management
  • 1.  re: HP5920 error
    Posted Sep 08, 2021 03:21 PM
    good day,
    need assistance with this warning message: The instance "[interface:Bridge-Aggregation12]" of "performance task" "Interface Transmitting Rate" is back to normal for threshold 2, current value is "96.263Mbps".
    thanks,
    David
    #imc
  • 2.  RE: re: HP5920 error
    Posted Sep 08, 2021 03:22 PM
    display link-aggregation member-port Ten-GigabitEthernet 1/0/11
    Flags: A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
    D -- Synchronization, E -- Collecting, F -- Distributing,
    G -- Defaulted, H -- Expired
    Ten-GigabitEthernet1/0/11:
    Aggregate Interface: Bridge-Aggregation11
    Local:
    Port Number: 11
    Port Priority: 32768
    Oper-Key: 11
    Flag: {ACDEF}
    Remote:
    System ID: 0x1000, 509a-4ce7-78f0
    Port Number: 34
    Oper-Key: 101
    Flag: {ACDEF}
    Received LACP Packets: 1551136 packet(s)
    Illegal: 0 packet(s)
    Sent LACP Packets: 1552134 packet(s)
    >display transceiver diagnosis interface t 1/0/11
    Ten-GigabitEthernet1/0/11 transceiver diagnostic information:
    Current diagnostic parameters:
    Temp.(▒▒C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
    30 3.31 7.19 -2.15 -1.88
    Alarm thresholds:
    High 73 3.80 13.20 1.00 0.00
    Low -3 2.81 1.00 -9.50 -10.30
    >display transceiver alarm interface t 1/0/11
    Ten-GigabitEthernet1/0/11 transceiver current alarm information:
    None
    display transceiver interface t 1/0/11
    Ten-GigabitEthernet1/0/11 transceiver information:
    Transceiver Type : 10G_BASE_SR_SFP
    Connector Type : LC
    Wavelength(nm) : 850
    Transfer Distance(m) : 80(OM2),20(OM1),300(OM3)
    Digital Diagnostic Monitoring : YES
    Vendor Name : HPE
    Ordering Name : JD092B
  • 3.  RE: re: HP5920 error
    Posted Sep 08, 2021 04:56 PM
    Hello @dlhall68 ,
    .You need to recheck the threshold into imc interface transmitting rate for threshold 2.
    By default value is set to 100mbps however interface supports 10g.
    Go to  Resource-->Performance Management-->Global Index Settings
    Select 'Interface Transmitting Rate' and modify the Threshold 2.
    Thanks!
