Re: IAP 215 and 315 don't join same cluster
  • 1.  Re: IAP 215 and 315 don't join same cluster
    Posted Mar 21, 2020 11:55 AM
    Hi guys,
    Finally I found the problem. Just one of the APs was in standalone mode. The point is an AP's GUI in standalone mode shows the same options like those in Instant mode (VC IP, cluster security, etc.), then you realize the AP is in standalone mode only when you go to Maintenance > Convert option
    Julian
