Re: iap-325 in mesh doesn't respect power settings
  • 1.  Re: iap-325 in mesh doesn't respect power settings
    Posted Apr 06, 2020 12:08 PM
    I experience the same issue in all 8.x versions
    Wired:
    IAP275# show aps
    2 Access Points
    Name IP Address Mode Spectrum Clients Type IPv6 Address Mesh Role Zone Serial # radio0 Channel radio0 Power (dBm) radio0 Utilization (%) radio0 Noise Floor (dBm) radio1 Channel radio1 Power (dBm) radio1 Utilization (%) radio1 Noise Floor (dBm) radio2 Channel radio2 Power (dBm) radio2 Utilization (%) radio2 Noise Floor (dBm) Need Antenna Config From Port Config Id Config Csum Ext SSID Active Age Link Local IP Address Uplink Port
    IAP275 192.168.30.109* access disable 1 275(outdoor) -- Portal - CL0016483 64 12 1(good) -96(good) 11 9 32(good) -96(good) - - - - No none 4 41017 disable 16h:43m:9s -- eth0
    IAP515 192.168.7.35 access disable 0 515(indoor) -- N/A - CNHQKD5D12 40 12 9(good) -93(good) 6 9 37(good) -89(good) - - - - No none 4 41017 enable 4m:35s fe80::f62e:7fff:fec9:7040 eth0
    Meshed:
    IAP275# show aps
    2 Access Points
    IAP275 192.168.30.109* access disable 1 275(outdoor) -- Portal - CL0016483 64 12 1(good) -96(good) 11 9 21(good) -96(good) - - - - No none 4 41017 disable 16h:47m:47s -- eth0
    IAP515 192.168.30.79 access disable 0 515(indoor) -- Point - CNHQKD5D12 64 30 1(good) -92(good) 6 9 32(good) -91(good) - - - - No none 4 41017 disable 35s -- Wifi-mesh
    IAP275#
  • 2.  RE: Re: iap-325 in mesh doesn't respect power settings
    Posted Apr 06, 2020 04:21 AM
    Hi!
    I have mesh built from iap-345 (wired) and iap-325 (wireless).
    power limits are 12-18 for 2.4g and 18-24 for 5g.
    despite limits iap-325 shows 30db for 5g and 26db for 2.4g, causing clients to stick to it, as signal is stronger even when standing next to iap-345.
    both AP running 8.6.0.3
    thanks!
  • 3.  RE: Re: iap-325 in mesh doesn't respect power settings
    Posted Apr 06, 2020 11:29 AM
    Where/how are you determining the output power?
  • 4.  RE: Re: iap-325 in mesh doesn't respect power settings
    Posted Apr 07, 2020 03:04 AM
    Hi!
    thanks for response.
    IAP-325# show ap bss-table
    Aruba AP BSS Table
    bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t flags
    b4:5d:50:d8:b7:12 home-net ?/? 192.168.0.6 a-VHT ap 149E/32.9/32.9 1 IAP-325 0 13h:50m:26s K
    b4:5d:50:d8:b7:02 home-net ?/? 192.168.0.6 g-HT ap 7+/15.0/26.7 1 IAP-325 0 13h:50m:25s K
