last person joined: 9 hours ago
Re: Phone number and SMS in CP Guest
  • 1.  Re: Phone number and SMS in CP Guest
    Posted May 30, 2013 02:41 AM
    To do that for every country isnt viable.. Add some good descriptive text with an example and it should solve it for most of your guests. You could also add a check on the value for the inputfield before submitting the form. If it doesnt start with 0 for swiss numbers, then give a more detailed message to the guest of how to input it correctly with +
  • 2.  RE: Re: Phone number and SMS in CP Guest
    Posted Jun 03, 2013 04:34 AM
    I agree with you. But the thing is that I am not sure how to configure the SMS Gateway using SMS Global as provider.
    Now it's like this :
    What I would like is that if the number as more than 10 digits (0111111111), it doesn't add the +41 before the 0. So for foreign numbers, users needs to use phone number like +033xxxxxxxxxxx.
    Exemple : 0793093112 -> 41793093112
                      0033xxyyzzaaa - > 0033xxyyzzaaa
                      0049152088336XX - > 0049152088336XX
    Dimitri
