Re: Problem adding IAP-207 to cluster of mixed IAP-205 IAP-207
  • 1.  Re: Problem adding IAP-207 to cluster of mixed IAP-205 IAP-207
    Posted Jun 26, 2020 11:17 AM
    Thanks, I understand, does exist a dashboard to see the differents brands 204/205/207/304 ?  Cause i've problems with some 304 for example and this could be the same solution.
    See you
  • 2.  RE: Re: Problem adding IAP-207 to cluster of mixed IAP-205 IAP-207
    Posted Jun 26, 2020 07:37 PM
    IAP-304/305 are the same except IAP-304 need external antennas where are 305 does not and has inbuilt antennas
    same thing for IAP-204/205 the even number at the end of model indicate that it requires external antennas.
  • 3.  RE: Re: Problem adding IAP-207 to cluster of mixed IAP-205 IAP-207
    Posted Jul 06, 2020 02:21 AM
    Thank you, but we were talking about the diffferents branchs, and models with same firmware, and we haven t found a sheet on the differents time of build for same Ap but differents client between Aruba , Alcatel and Dell.
  • 4.  RE: Re: Problem adding IAP-207 to cluster of mixed IAP-205 IAP-207
    Posted Jul 06, 2020 03:12 AM
    I am not sure about the OEM branded APs, They would be running some OEM version of firmware.
    IAP-207 and IAP-204/5 were end of sale jun 2019 and 2018 respectively
    https://www.arubanetworks.com/support-services/end-of-life/#AccessPoints
     thats why you cant find their datasheets. The direct replacement is AP304/5 if you want 11ac wave2 and AP 505 for 11ax.
  • 5.  RE: Re: Problem adding IAP-207 to cluster of mixed IAP-205 IAP-207
    Posted Jul 06, 2020 03:33 AM
    Ok , one information I miss was same oem on same cluster otherwise don t join,
    Now it s solved
    Envoyé depuis mon smartphone Samsung Galaxy.
