last person joined: 5 hours ago
Re: soundtouch Bose 30
  • 1.  Re: soundtouch Bose 30
    Posted Jan 02, 2017 08:03 PM
    Hi Colin, I don't want to disable airgroup on my AP but the thing that I made was to upgrade my IAP205 to latest firmware option and the issue got resolved. The only change that I made was under the SSID with the Broadcast Filtering.
    Thanks for your support!
