last person joined: 10 hours ago
reauth not working
This thread has been viewed 27 times
  • 1.  reauth not working
    Posted Jan 03, 2020 07:21 AM
    Hello , I am using a MAC auth service for non standard devices .
    the devices are discovered by DHCP profiling . I have put the session timeout profile with value as 36000 seconds in the enforcement rule . So i want all non standard devices to reauthenticate after 10 hours
    enforcement profile is type RADIUS
    Radius:IETF Session-Timeout = 36000
    But i dont see reauthentication happening because of which i cant see these devices doing authentication in daly reports generated by Insight . Does reauth works only for dot1x ? or do i have to use Profile type as RADIUS_COA ?
    The NAD is Cisco running with latest IOS version
  • 2.  RE: reauth not working
    Posted Jan 03, 2020 07:34 AM
    Before asking more specific questions, did you use the Cisco section of the ClearPass Wired Policy Enforcement Guide here to setup your enforcement on the Cisco and ClearPass side?  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=33276
    Reauthentication can involve more than just sending a radius attribute.
  • 3.  RE: reauth not working
    Posted Jan 03, 2020 07:40 AM
    Hi Joseph ,
    Yes i did followup the wired guide .
    Session time out of 36000 should make any active session breack after 10 hours . So what is the need of reauth parameters . ?
    Or does this mean that session time out wont initiate a new reauth request ? This is more specific for devices hitting MAC auth service .
  • 4.  RE: reauth not working
    Posted Jan 03, 2020 07:44 AM
    There is Cisco-specific configuration that is needed for the Cisco NAD to enforce a radius-supplied session-timeout.  Please see here:  https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_8021x/configuration/15-mt/sec-user-8021x-15-mt-book/sec-ieee-8021x-rad-supp-sess-t.html
  • 5.  RE: reauth not working
    Posted Jan 03, 2020 07:49 AM
    This talks about dot1x . but i believe it will work for MAC Also ?
  • 6.  RE: reauth not working
    MVP EXPERT
    Posted Jan 03, 2020 09:37 AM
    802.1x is just radius, eap or mac is the inner authentication methode send by the supplicant (client). It could be that cisco need some specific configuration on the authenticator (switch). Iam not very familar with cisco.
    For a Aruba switch its works based on both EAP and MAC authentintication with 802.1x.
    See my screenshots attached for an example.
    Seems like that the lowest value of the sesion-timout is 60sec. ;).
    For reference: In my test setup it stopped working directly after i remove the radius:ietf-termination attribute. So give it a try.
  • 7.  RE: reauth not working
    Posted Jan 03, 2020 09:57 AM
    Thanks a lot Marcel. I will try and let you know.
  • 8.  RE: reauth not working
    Posted Jan 08, 2020 11:47 AM
    I have configured below
    1. Radius:IETF Session-Timeout = 3600
    2. Radius:IETF Termination-Action = RADIUS-Request (1)
    3. Radius:IETF Tunnel-Medium-Type = IEEE-802 (6)
    But it is not even considering 3600 seconds and doing reauth again and again after on average 80-90 seconds
    The Access switch is Cisco
  • 9.  RE: reauth not working
    Posted Jan 08, 2020 12:24 PM
    Check this cisco document
    https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_8021x/configuration/15-mt/sec-user-8021x-15-mt-book/sec-ieee-8021x-rad-supp-sess-t.pdf
    Information About IEEE 802.1X RADIUS-Supplied SessionTimeoutIEEE 802.1X RADIUS-Supplied Session Timeout
    You can specifywhethera device port uses a locallyconfiguredor a RADIUS-providedreauthenticationtimeout.If the device port is configuredto use the local timeout,it reauthenticatesthe host when the timerexpires.IfthedeviceportisconfiguredtousetheRADIUS-provided timeout,itlooksintheRADIUSAccess-Acceptmessagefor the Session-Timeoutand optionalTermination-Actionattributes.The device port uses the valueof the Session-Timeoutattributeto determinethe duration of the session,and it uses the value of theTermination-Action attribute to determinethe device action when the sessions timer expires.IftheTermination-ActionattributeispresentanditsvalueisRADIUS-Request,the device port reauthenticatesthe host. If the Termination-Actionattributeis not present,or its value is Default,the device port terminatesthe session.
    Enforcenment profile which you configured should work, try check if configuration done on switch proper. Document provide configuration part aswell.
  • 10.  RE: reauth not working
    MVP EXPERT
    Posted Jan 08, 2020 12:27 PM
    Did you configure the radius:IETF Tunnel-Type and radius:IEFT Tunnel-Private-Group-ID? for pushing the vlan. Does the client get an IP?
    What is you aaa settings for your cisco switch look like?
    Session timeout can be configured on the switch or at the server derivation.
  • 11.  RE: reauth not working
    Posted Jan 08, 2020 01:15 PM
    We are not sending vlan as vlan id will be different for each site
    Below is our Cisco 9300 config
    interface GigabitEthernet1/0/27
     description ** USER DATA CONNECTIVITY **
     switchport access vlan 219
     switchport mode access
     authentication event server dead action authorize vlan 219
     authentication event server alive action reinitialize
     authentication host-mode multi-domain
     authentication order dot1x mab
     authentication priority dot1x mab
     authentication port-control auto
     authentication timer reauthenticate server
     mab
     storm-control broadcast level 3.00
     storm-control multicast level 3.00
     dot1x pae authenticator
     dot1x timeout tx-period 10
     dot1x timeout supp-timeout 15
     dot1x max-reauth-req 1
     spanning-tree portfast
     spanning-tree bpduguard enable
  • 12.  RE: reauth not working
    MVP EXPERT
    Posted Jan 08, 2020 01:36 PM
    Ok, without vlan enforcement you dont need the "tunnel-medium-type" attribute.
    Last question was not answerd, does your client get an IP address in that 60-90secs?
    Your aaa config looks fine to me, but iam not a cisco expert, i learn also from your info ;).
    Do you check the wired enforcement policy guide page 128
    https://community.arubanetworks.com/aruba/attachments/aruba/CampusSwitching/3907/2/ClearPass_Solution-Guide_Wired-Policy-Enforcement_v2018-01.pdf
  • 13.  RE: reauth not working
    Posted Jan 08, 2020 01:54 PM
    yes client gets the IP address everytime .
  • 14.  RE: reauth not working
    Posted Jan 08, 2020 02:10 PM
    We have 3750x's so syntax might be different, but can you run your version of this command?
    show authentication sessions interface gi1/0/1
    Should see something similar to this (again I don't know how different the 9300s are)
    <hostname>#show authentication sessions interface gi1/0/1
    Interface: GigabitEthernet1/0/1
    MAC Address: <<MAC Address>>
    IP Address: Unknown
    User-Name: <<Username>>
    Status: Authz Success
    Domain: DATA
    Security Policy: Should Secure
    Security Status: Unsecure
    Oper host mode: multi-host
    Oper control dir: in
    Authorized By: Authentication Server
    Vlan Policy: 2012
    Session timeout: 64800s (server), Remaining: 6883s
    Timeout action: Reauthenticate
    Idle timeout: N/A
    Common Session ID: C0A80A3D00892194FDC2B87B
    Acct Session ID: 0x00893301
    Handle: 0x3F000689
    Runnable methods list:
    Method State
    dot1x Authc Success
    mab Not run
  • 15.  RE: reauth not working
    Posted Jan 08, 2020 02:22 PM
    below is the output from our 3750 WS-C3750X-48P and OS is 15.2(4)E7
    show authentication sessions interface Gi3/0/30 details
    Interface: GigabitEthernet3/0/30
    MAC Address: 10e7.c633.a36f
    IPv6 Address: Unknown
    IPv4 Address: 10.116.35.152
    User-Name: test-pc.domain.test
    Status: Authorized
    Domain: DATA
    Oper host mode: multi-domain
    Oper control dir: both
    Session timeout: N/A
    Restart timeout: N/A
    Periodic Acct timeout: N/A
    Common Session ID: 0A74230500000D606E3799AA
    Acct Session ID: 0x00000BFC
    Handle: 0xEF000D4F
    Current Policy: POLICY_Gi3/0/30
    RAdius is only sending Radius:IETF Session-Timeout = 36000
    seems port is not taking .
    can you share your port config from 3750 . Here we are using multidomain while you are using multi auth
  • 16.  RE: reauth not working
    Posted Jan 08, 2020 02:37 PM
    Sure
    interface GigabitEthernet1/0/1
    description A-02 AP
    switchport access vlan 110
    switchport voice vlan 604
    authentication control-direction in
    authentication host-mode multi-host
    authentication periodic
    mab
    dot1x timeout tx-period 4
    end
    This specific switch is running 15.0, we have another switch running 15.2(4)E6 that is experiencing the same thing you are having, so I'm going to look into that and see what I can find
  • 17.  RE: reauth not working
    Posted Jan 08, 2020 02:51 PM
    My BAd
    I was missing the below command
    After adding this command , everything seems to work
    Thanks all for your suggestions
  • 18.  RE: reauth not working
    MVP EXPERT
    Posted Jan 08, 2020 03:23 PM
    Good thats working now. Thanks for your feedback so we can all learn from this! Keep strong (y).
  • 19.  RE: reauth not working
    MVP EXPERT
    Posted Jan 03, 2020 07:42 AM
    Did you try to set the Radius:IETF:Termination-action = Radius-Request aswell in your enforcement profile?
  • 20.  RE: reauth not working
    Posted Jan 03, 2020 07:48 AM
    Hi , i have not set it up . i will set and check . This should work for endpoints doing MAC auth as well ?
