Reboot a AP connected to ArubaS2500-24P
  • 1.  Reboot a AP connected to ArubaS2500-24P
    Posted Jul 20, 2018 01:45 PM
    Hello Team,
    Can you please update  me the command to reboot the AP through the reomval of power connected to my ArubaS2500-24P switch.
    On my Aruba 2930F swicth I perform the following the command
    #no interface <PORTS> power-over-ethernet
    (to reboot the device through the removal of power)
    The above mentioned command does not work for ArubaS2500.
    So can you help with this. Thanks in advance.
    Haresh Niwate
  • 2.  RE: Reboot a AP connected to ArubaS2500-24P
    MVP EXPERT
    Posted Jul 22, 2018 03:52 AM
    Have you tried the ArubaOS shutdown/no shutdown commands which should work, for example:
    (ArubaS3500) #configure t
    Enter Configuration commands, one per line. End with CNTL/Z
    (ArubaS3500) (config) #interface gigabitethernet 1/8
    (ArubaS3500) (config-if)#shutdown
    (ArubaS3500) (config-if)#no shutdown
  • 3.  RE: Reboot a AP connected to ArubaS2500-24P
    Posted Jul 22, 2018 01:29 PM
    Hi Zalion,
    Thanks for response. Yes I have tried the shutdown command. However shut and no shutdown command will bounce the interface. I would just  like to shut the poe without bouncing the interface.
    Haresh Niwate
  • 4.  RE: Reboot a AP connected to ArubaS2500-24P
    MVP EXPERT
    Posted Jul 22, 2018 02:11 PM
    Have you tried removing the POE profile from the port?
    Sent from my iPhone
  • 5.  RE: Reboot a AP connected to ArubaS2500-24P
    Posted Jul 23, 2018 05:49 AM
    Zalion the following commands helped. Thanks for your assistance.
    poe-profile poe-disabled
    poe-profile poe-factory-initial
