last person joined: 11 hours ago
Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
  • 1.  Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Jun 18, 2014 03:16 AM
    Hi Guys,
    Im getting a strange reboots (M3 + 6.3.1.8)
    this is what i got in the log:
    Anyone can say to me what might be the cause?
  • 2.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Jun 18, 2014 04:13 AM
    Is there any syslog id associated with that message?  I can't seem to see anything in the 6.3 Syslog message guide that matches that.
    If there is a crash file available on the controller, you should send this to TAC to investigate.  Really, any unexpected reboot should be investigated by the TAC guys.
  • 3.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Jun 18, 2014 05:54 AM
    Crashes do not have a syslog ID, because they are unexpected.  Please open a TAC case.
  • 4.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Oct 30, 2014 06:32 AM
    We are seeing the exact same error message repeat endlessly after an upgrade of our M3 controllers to v6.4.2.2. 2 of the 4 controllers in the same chassis came up fine, 2 are in this endless reboot loop.
    We havv opened a TAC case. We are online with them now and have been for hours. We do not seem to be getting anywhere
    If anyone has solved this issue or knows about a solution. Please chime in.
  • 5.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Nov 17, 2014 06:28 PM
    We are having the same error on our secondary controller in our HA pair. It's been rebooting itself at least once a day with that error. It did it again today and hasn't come back online yet. It's been down for over an hour now.
    We are running 6.3.1.13 on an Aruba6000-US
  • 6.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Nov 17, 2014 06:29 PM
    That is definitely not a routine occurrence. Please open a TAC case asap.
  • 7.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Apr 01, 2015 06:20 AM
    Can I check with firmware has fixed this issue?
  • 8.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Jan 18, 2023 06:43 PM
    I am seeing the exact same issue with Aruba 7010 - running IOS: 8.5.0.9...receive the same error each time and then the WLC reboots, randomly... Reboot Cause: Power Cycle (Intent:cause:register ee:ee:50:3)
    Suggestions?
  • 9.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Jan 26, 2023 11:22 AM
    May be a software issue or hardware issue. Please work with Aruba TAC Support. ArubaOS 8.5.0.9 is old and end of support, You may consider upgrading to a more recent version, if you have active support on the device and access to the firmware downloads.
  • 10.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Jan 26, 2023 04:07 PM
    This same 7010 WLC was doing the exact same thing on IOS v6.4.4.x-FIPS and ran for years without an issue for testing. The WLC was doing the same reboots constantly (every 3-4 hrs) where I upgraded to it's current code - v8.5.x.x and it's doing the same thing, still.
  • 11.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Jan 27, 2023 05:38 AM
    If software upgrade doesn't solver the issue, it's likely a hardware issue. Please work with Aruba TAC Support.
  • 12.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Feb 04, 2023 12:33 PM
    Software upgrade? = No improvement
    TAC assistance? = No improvement/solutions provided and no recommendations at this point.
    Looking through blogs, AirHeads, etc. this is not a regular occurrence, but it has/does happen on various OS versions. Thus far have not seen any solutions to the issue. From research this issue was first reported/logged online as far back as 2014 with no recommendations other than OS upgrade which has been performed, 3X, with no success.
  • 13.  RE: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
    Posted Feb 05, 2023 08:30 AM
    The message itself is generic.  The details on why it happens and the remedy needs to be provided by Technical Support and Engineering.
