Received low POE power
  • 1.  Received low POE power
    Posted Feb 18, 2020 09:51 AM
    We just start testing Aruba AP's for our deployments. First site right now we devices having issues to connect (where before a home use router WiFi was working like a charm) , but before we jump into signal troubleshooting we are seeing a lot of events that comes in waves:
    Event Type: "AP Insufficient Power Supply"
    Description: "Received low POE power" from the AP-303 test unit.
    Using POE: HPE Aruba PD-3501G-AC - PoE injector - 15.4 Watt part number: JW627A
    Can that be due to a faulty POE injector?
    Thank you in advance.
    Mario
  • 2.  RE: Received low POE power
    MVP GURU
    Posted Feb 18, 2020 10:23 AM
    Might be. That PoE injector is IEEE 802.3af compliant, and as far as i know you shouldn't need more than 15.4 Watt on that AP. Are all radios up on the AP. Usually when an AP doesn't receive full power, it will shut off one of the radios.
  • 3.  RE: Received low POE power
    Posted Feb 18, 2020 10:25 AM
    Yes, all radios on. besides the bad coverage I don't see any other error.
    Thank you
    Mario
  • 4.  RE: Received low POE power
    Posted Feb 18, 2020 08:18 PM
    AP-303 operates without restrictions from any 802.3af POE source.
    Getting a message about insufficient POE power makes no sense.
    Where was this observed?
  • 5.  RE: Received low POE power
    Posted Feb 19, 2020 01:38 AM
    ARUBA Central under events of the AP- 303
    Mario
  • 6.  RE: Received low POE power
    Posted Mar 04, 2020 06:25 PM
    Efectivamente...a mi me pasa lo mismo...la unica falla que tengo es la cobertura. Por mi parte subi manualmente la potencia de los radios y mejoro un poco sin embargo creo que será mejor utilizar un 802.3at que es lo que recomienda ARUBA CENTRAL
