Recieving mac address as username and ongurad issue
  • 1.  Recieving mac address as username and ongurad issue
    Posted Sep 04, 2013 11:47 AM
    I am implementing ClearPass in one of the organizations .I am still in testing phase of 7 PCs.
     I couldn’t move forward to the next phase because of the issue I am getting .
    This is the scenario we are using:
    1- The users will be in the access VLAN with DACL restricting them from accessing the whole network.
    2- web-auth service will be triggered by ONGUARD and posture will decide if it's healthy or not (quarantine).
    3- If it was healthy the onguard will bounce the port and will allow the user to access.
    These are the problems we are facing:
    - Onguard on some PCs are quitting automatically after some time (with no action of the user). Just disappear.
    This happened twice on different PCs. I am not sure why?
    -  On one of the PCs the web-auth was not triggering automatically. The user remained restricted by the DACL till I did it manually from the user PC using the button "Retry" on the ONGUARD.
    - For some of the PCs , after some time of being idle, the CPPM start receiving requests with the MAC address of those PCs rather than using usernames . Which are rejected always. Also after the user login to windows , the same issue continues and the user needs to disable/enable network NIC. Then it starts receiving dot1x requests with the actual usernames.
    This is happening for some PCs. Other PCs are fine .
    Please any suggest!!
  • 2.  RE: Recieving mac address as username and ongurad issue
    Posted Sep 04, 2013 11:48 AM
    Just to add that this is wired setup
  • 3.  RE: Recieving mac address as username and ongurad issue
    Posted Sep 04, 2013 01:32 PM
    This isn't an issue for these forums.  This sounds config (incl wired switch) ++ client related.  Please open a case for further assistance.
