Recommended 6.7.x Patch
  • 1.  Recommended 6.7.x Patch
    Posted Jun 14, 2018 04:43 PM
    After upgrading to 6.7.0, the option to upgrade under software updates is 6.7.4 which i noticed that was recently realesed.
    What is the recomended patch to go to 6.7.x ? or should i stay in 6.7.0 ?
    I am running (4)-25K appliances (1 master/publisher and 3 subscribers) on a major Healthcare enviroment using (wireless auth, Onboard, GuestNet, Tacacs, Radius and so on)
    Only thing i have noticed so far are TLS erros/rejects for some clients on access tracker.
    AP
  • 2.  RE: Recommended 6.7.x Patch
    Posted Jun 14, 2018 04:51 PM
    6.7.4.
  • 3.  RE: Recommended 6.7.x Patch
    Posted Jun 14, 2018 07:05 PM
    Hi
    Do you mean 1 master and 3 publishers or 1 publisher and 3 subscribers?
    What Tim recommended should be the best option! Tim knows his stuff!!
  • 4.  RE: Recommended 6.7.x Patch
    Posted Jun 19, 2018 11:22 AM
    Correct, 1 Master/Publisher and 3 Subscribners
    After upgraded to 6.7 i am having a lot of issues wqith IOS devices and TLS certificate errors, any recomemdations?
    Error Code:
    215
    Error Category:
    Authentication failure
    Error Message:
    TLS session error
     Alerts for this Request
    RADIUSEAP-TLS: warning alert by client - close_notify
    TLS Handshake failed in SSL_read with error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure
    eap-tls: Error in establishing TLS session
  • 5.  RE: Recommended 6.7.x Patch
    Posted Jun 19, 2018 12:11 PM
    Install 6.7.4
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 6.  RE: Recommended 6.7.x Patch
    Posted Jun 19, 2018 02:01 PM
    Any pre-update recomendations?
    I know i had to re install all certificates after my last update to 6.7 also load all licenses (due to license conversion).
    It will be done via the cluster upgrade tool, a few things i always do is disable "Standby Publisher" as well as Daily backups.
    Any suggestions are welcome, our CPPM main use includes:
    -Radius Authentication (wireless)
    -Tacacs +
    -EAP-TLS OCSP/ SCEP for MDM onboarding
    -GuestNet splash page services
    Andres
  • 7.  RE: Recommended 6.7.x Patch
    Posted Jun 19, 2018 06:07 PM
    Upgrade to 6.7.4 has been completed suscesfully......but unfortunately i see the same TLS erros as before :(
    I guess next is to open a support ticket and take it from there.
    Andres
  • 8.  RE: Recommended 6.7.x Patch
    Posted Jun 19, 2018 08:11 PM
    What is the error on the alert tab?
    With regards,
    Frank
    Sent from a mobile device
    Disclaimer: Dit e-mail bericht is alleen bestemd voor de geadresseerde, verstrekking aan en gebruik door anderen is niet toegestaan. Indien u niet de geadresseerde bent, wordt u vriendelijk verzocht de verzender hiervan op de hoogte te stellen en het bericht te verwijderen. In verband met de elektronische verzending kunnen aan de inhoud van dit bericht geen rechten worden ontleend.
  • 9.  RE: Recommended 6.7.x Patch
    Posted Jun 20, 2018 10:21 AM
    Error Code:
    215
    Error Category:
    Error Message:
    TLS session error
  • 10.  RE: Recommended 6.7.x Patch
  • 11.  RE: Recommended 6.7.x Patch
    Posted Jun 19, 2018 11:30 AM
    Always go for 6.7.3 or 6.7.4 at this moment.
    A lot of fixes were done in those patches.
    With regards,
    Frank
