Recommended IAP firmware version upgrade
This thread has been viewed 69 times
  • 1.  Recommended IAP firmware version upgrade
    Posted Jun 07, 2021 12:31 PM
    We have IAP-305, -315 and -365Outdoor access points in our district. All are currently running firmware version 8.6.0.6-8.6.0.6_77124.
    We just purchased an AP-577EX and an AP-575EX for one of our buildings. It appears that the minimum firmware version for these if in the 8.7 series, so in order to add them to an existing instant cluster we will need to upgrade the current virtual controller to 8.7.x.x.
    Is there a recommended version of 8.7 to go to from 8.6.0.6?
    Thanks.
    Jon Koelker
  • 2.  RE: Recommended IAP firmware version upgrade
    Posted Jun 07, 2021 09:53 PM
    go with the latest maintenance release which is 8.7.1.3
    here is the release notes
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00112378en_us
  • 3.  RE: Recommended IAP firmware version upgrade
    Posted Jun 08, 2021 01:21 PM
    Thank you!
    Jon Koelker
  • 4.  RE: Recommended IAP firmware version upgrade
    Posted Jun 15, 2021 10:28 AM
    Hi, ariyap - a quick question: are you aware of any issues with the 8.7.1.3 firmware version for IAPs? We upgraded to that version from 8.6.0.6 on two of our IAP clusters and almost immediately began receiving thousands of alerts in AirWave of this type:
    meshd[6290]: meshd_anulmesh_link_table_check: LINE 2 no
    peer MAC
    meshd[6290]: meshd_anulmesh_link_table_check: LINE 1
    link mode<Bridge> is not WIFI
    meshd[6290]: meshd_anulmesh_link_table_check: open
    anulmesh link table succeed
    The only way I could stop them was to remove the alert trigger from AirWave. Do you happen to know if this a known issue with this firmware version?
    Thanks.
    jk
    Jon Koelker
  • 5.  RE: Recommended IAP firmware version upgrade
    Posted Jun 17, 2021 11:25 AM
    Please reach out to Aruba TAC to get this investigated (which I think you have done already).
